Ghostsailor 1 Posted September 28, 2020 Posted September 28, 2020 Hey Guys, Is there a option to show when a user was logged in the last time? Like "User2" was last logged in on February 2019. I need this to see if I have non active users on my database which I then could simply delete.
Carlo 4561 Posted September 29, 2020 Posted September 29, 2020 Hi, You may want to check the Playback Reporting plugin as well as the Statistics plugin. You should be able to find the info you're looking for from either of those two plugins.
Luke 42208 Posted September 29, 2020 Posted September 29, 2020 We plan to add more sorting and filtering in the users management screen to make this easier to do. Thanks for the feedback.
Ghostsailor 1 Posted October 7, 2020 Author Posted October 7, 2020 Thank you very much for your replies. Maybe you could add a way to display when a user was last logged in in the statistics app.
Happy2Play 9802 Posted October 7, 2020 Posted October 7, 2020 (edited) 1 hour ago, Ghostsailor said: Maybe you could add a way to display when a user was last logged in in the statistics app Unless another dev wants to make these changes this plugin is no longer maintained by the developer. On 5/26/2016 at 9:46 AM, reggi said: Announcement: As of today (30/04/2018), I will no longer update this plugin. Only fix it when there is a Nuget Package update needed. This is because I'm working on a standalone statistics server. Here you can find the main forum thread for EmbyStat. If you have any ideas, design layouts, development knownledge feel free to participate there or on the github repo Thanks everyone for all the support, testing and patience that made this plugin grown. But I think to get even better and more statistics, a standalone server is the way to go. The Playback Reporting plugin does maintain the information you are looking for though. User Last Activity Media 13 hours 26 minutes Edited October 7, 2020 by Happy2Play
