Spaceboy 2573 Posted November 25, 2018 Posted November 25, 2018 Just a note, after merging a 1080p and 2160p version into the same group, I watched the 4K one but the 1080p remains unwatched. If they're grouped I would imagine the desired effect would be to mark both as watched? Even after forcing an import from Trakt it still doesn't mark the other one as watched. Also in collections it still lists them as separate movies, not sure if that again is by design or not. what if the different versions were a directors cut and a theatrical cut. So actually different movies. Would you still expect them both to be shown as watched?
Luke 42246 Posted November 25, 2018 Posted November 25, 2018 We probably do need some handling here, yes.
ebr 16338 Posted November 26, 2018 Posted November 26, 2018 Just a note, after merging a 1080p and 2160p version into the same group, I watched the 4K one but the 1080p remains unwatched. If they're grouped I would imagine the desired effect would be to mark both as watched? Even after forcing an import from Trakt it still doesn't mark the other one as watched. Also in collections it still lists them as separate movies, not sure if that again is by design or not. If you've used our multi-version naming then they would show as a single item so there would be no way for them to have different watched status...
shrouski 7 Posted November 26, 2018 Posted November 26, 2018 what if the different versions were a directors cut and a theatrical cut. So actually different movies. Would you still expect them both to be shown as watched? Personally? Yes, I would want all versions marked as watched since if I have different versions, I'm going to just watch the Directors/Theatrical cut in the first place which will contain all the content from every version. If you've used our multi-version naming then they would show as a single item so there would be no way for them to have different watched status... I haven't because it makes it impossible to seed, so I've manually grouped them. They are the same movie just 1080p BluRay and 2160p Remux. Only one remains watched. Surely the other one should become watched once you pull it in from Trakt also? If neither movie is watched and I mark it as watched on Trakt, both get marked as watched, but something is preventing the other from being marked as watched when I watch one of them through Emby. It's probably a debatable topic as I'm sure others will have a different opinion to me, but I don't really have the desire to watch the same movie 3 times with slightly different versions.
ebr 16338 Posted November 26, 2018 Posted November 26, 2018 Are both versions identified properly with the same TMDB ID? If so, they should share watched status.
shrouski 7 Posted November 26, 2018 Posted November 26, 2018 Are both versions identified properly with the same TMDB ID? If so, they should share watched status. Yep, both the same under Meta Data Manager, but only one was flagged as watched after watching it.
ebr 16338 Posted November 26, 2018 Posted November 26, 2018 Yep, both the same under Meta Data Manager, but only one was flagged as watched after watching it. They both had the exact same IDs defined in the exact same order?
shrouski 7 Posted November 26, 2018 Posted November 26, 2018 They both had the exact same IDs defined in the exact same order? Yeah, IMDB, TMDB and TMDB Collection ID's are all identical. These were manually grouped together by myself and then watched after that.
ScottRTL 6 Posted November 9, 2020 Posted November 9, 2020 It's been forever... How about make multiple endings an option available upon playing a movie in emby. I am legend The butterfly effect Little shop of horrors We should be able to choose the ending, when we start. And select the different (alternate) endings from a list available, like special features.
ebr 16338 Posted November 9, 2020 Posted November 9, 2020 Hi. Most of the players used on most of our platforms are not likely to support this kind of thing directly. However, you could do this right now by simply muxing the different endings into different versions of the item using our multi-version feature.
ScottRTL 6 Posted November 9, 2020 Posted November 9, 2020 Please elaborate on muxing and the multi-version feature. Thanks 7 hours ago, ebr said: Hi. Most of the players used on most of our platforms are not likely to support this kind of thing directly. However, you could do this right now by simply muxing the different endings into different versions of the item using our multi-version feature.
ebr 16338 Posted November 9, 2020 Posted November 9, 2020 1 hour ago, ScottRTL said: Please elaborate on muxing and the multi-version feature. Just create separate video files for each ending and use our multi-version naming to make them show up in a drop down like you wanted.
MSOBadger 13 Posted September 23, 2022 Posted September 23, 2022 (edited) Sorry to revive an old thread, but this after searching the forums, this seemed like the best place for this question. Plex has incorporated Edition tagging in its naming conventions - with the {edition-Movie Edition Name Here} tag in file names, similar to how they treated IMDB or TMDBID tags. Generally Emby has incorporated compatibility for Plex's naming conventions. Is there a plan to incorporate Plex's Edition tag into Emby? Additionally, Plex's incorporation of the Edition tag also included some enhanced functionality for multiple editions in the app itself. Anything like that on Emby's roadmap? Personally, I would LOVE to see this. Edited September 23, 2022 by MSOBadger
Luke 42246 Posted September 23, 2022 Posted September 23, 2022 2 hours ago, MSOBadger said: Sorry to revive an old thread, but this after searching the forums, this seemed like the best place for this question. Plex has incorporated Edition tagging in its naming conventions - with the {edition-Movie Edition Name Here} tag in file names, similar to how they treated IMDB or TMDBID tags. Generally Emby has incorporated compatibility for Plex's naming conventions. Is there a plan to incorporate Plex's Edition tag into Emby? Additionally, Plex's incorporation of the Edition tag also included some enhanced functionality for multiple editions in the app itself. Anything like that on Emby's roadmap? Personally, I would LOVE to see this. Hi, yes it's possible for future updates. Thanks. 1
MSOBadger 13 Posted September 23, 2022 Posted September 23, 2022 8 hours ago, Luke said: Hi, yes it's possible for future updates. Thanks. That's great! Thanks @Luke!
neik 874 Posted September 24, 2022 Posted September 24, 2022 33 minutes ago, daedalus said: oh boy, u have much to learn here We've all been there...
