Przemek 70 Posted October 27, 2021 Posted October 27, 2021 Hello, my friend who use my Emby server also have problem to connect from Android smart tv and Android tablet. He put wright https:// ...ddns.net address and port and he get output that cannot connect. Please contact admin. Regards.
Luke 42246 Posted October 27, 2021 Posted October 27, 2021 3 minutes ago, Przemek said: Hello, my friend who use my Emby server also have problem to connect from Android smart tv and Android tablet. He put wright https:// ...ddns.net address and port and he get output that cannot connect. Please contact admin. Regards. Are you sure the address is correct? What type of ssl certificate?
Przemek 70 Posted October 27, 2021 Posted October 27, 2021 (edited) Yes, the same address. He send me video. I use letsencrypt and no-ip.com. My friend has that app on TV: Regards Edited October 28, 2021 by Przemek
Nanganator 3 Posted October 28, 2021 Posted October 28, 2021 Yep, welcome to the suck of an expired DST Root CA X3. Been loads of warnings about it for a while. The Emby app doesn’t use its own root certificate store. It uses the one on the device. Chances are the device manufacturer hasn’t bothered to issue updates in ages for the devices and now they have an expired root certificate meaning your letsencrypt certificate on your Emby server is considered as being issued by an untrusted source.
Przemek 70 Posted October 28, 2021 Posted October 28, 2021 Sorry but I don't understand. I have my Emby server with certbot and letsencrypt certificate and everything works. This TV app is not official android TV app?
Luke 42246 Posted October 28, 2021 Posted October 28, 2021 5 minutes ago, Przemek said: Sorry but I don't understand. I have my Emby server with certbot and letsencrypt certificate and everything works. This TV app is not official android TV app? It is an official android TV app, but your certificate is not natively trusted by android devices, and our TV app does not yet have a workaround for this. Our standard app does, which you can also install on TV devices via sideloading: https://emby.media/emby-for-android.html
bandit8623 226 Posted October 31, 2021 Posted October 31, 2021 (edited) On 10/28/2021 at 2:59 PM, Luke said: It is an official android TV app, but your certificate is not natively trusted by android devices, and our TV app does not yet have a workaround for this. Our standard app does, which you can also install on TV devices via sideloading: https://emby.media/emby-for-android.html just sideloaded on 2 fire sticks today and the keyboard does not pop up.... cant enter server info. the app i sideloaded last week worked??? did something change? Edited October 31, 2021 by bandit8623
Luke 42246 Posted November 1, 2021 Posted November 1, 2021 22 hours ago, bandit8623 said: just sideloaded on 2 fire sticks today and the keyboard does not pop up.... cant enter server info. the app i sideloaded last week worked??? did something change? @bandit8623 are you sure it was just last week? What version number did you previously have?
bandit8623 226 Posted November 1, 2021 Posted November 1, 2021 (edited) 38 minutes ago, Luke said: @bandit8623 are you sure it was just last week? What version number did you previously have? The 25th on my other thread. I went on the app I had sideloaded on the 25th and could get to the keyboard.. then I downloaded the version on the link yesterday and then the keyboard would not pop up. Also same thing yesterday on a fire stick not in my home. I don't know the versions. All I know is the one I downloaded yesterday on 2 sticks wont allow the keyboard to pop up. Used this link both times Edited November 1, 2021 by bandit8623
bandit8623 226 Posted November 1, 2021 Posted November 1, 2021 16 minutes ago, Luke said: OK we'll look into it, thanks. thanks
