Meerkater 1 Posted September 27, 2020 Posted September 27, 2020 Hi, Since the latest update of Emby server to 4.5.0.50 on a Raspberry Pi 4 I have issues when playing music (.flac) on Yamaha Receiver RX-V481D via channel 'server'. After more than a minute the song skips to the next one. I didn't have this issue before this update. I already tried restarting the server but this didn't solve the issue. In attachment you can find the log file. Thanks for your feedback. Kind regards, Meerkater embyserver.txt hardware_detection-63736794051.txt
Meerkater 1 Posted October 2, 2020 Author Posted October 2, 2020 (edited) Yesterday I've upgraded to the latest version: 4.5.1.0. The problem seemed to be fixed for a couple of songs but now it is back... Every song please on average for 1:40 and then it skips to the next one. Can you please look into this? I've added a new log file. Thanks embyserver.txt Edited October 2, 2020 by Meerkater
Meerkater 1 Posted October 3, 2020 Author Posted October 3, 2020 Hi, I don't know if this could cause issues but I've just downgrade Emby to 4.4.3.0 and now everything is working as before. So, I guess something changed in version 4.5. Kind regards, Robin
Meerkater 1 Posted October 8, 2020 Author Posted October 8, 2020 Hi, I tried the latest update to 4.5.2 but the issue still exists. Kind regards, Robin
battykoda 0 Posted October 13, 2020 Posted October 13, 2020 (edited) I'm having exactly the same issue. song's skips after around 3 minutes I'm running the latest version. I had an old version on a virtual machine who was working fine. Reinstall my server on a new computer and it start doing that. Edited October 13, 2020 by battykoda
Luke 42237 Posted October 14, 2020 Posted October 14, 2020 Ok, we're looking into it. Thanks for reporting.
Meerkater 1 Posted October 15, 2020 Author Posted October 15, 2020 Thanks for looking into it. If you need any more information, don't hesitate to let me know.
pontch 0 Posted November 5, 2020 Posted November 5, 2020 Hey Guys, I wanted to inform you about the same issue with my Yamaha R-N602 receiver. Since i've installed the Version 4.5 of Emby Server IT skipps the Tracks after a Minute. Also i have installed the latest Beta Version and IT still Happend. Thank you
Luke 42237 Posted November 5, 2020 Posted November 5, 2020 Hi, would you mind trying beta server 4.6.0.5+ and let me know if that helps? Thanks.
battykoda 0 Posted November 6, 2020 Posted November 6, 2020 WOW! It worked! Thank you so much -- INSTALL BETA 4.6.0.5 VERSION FIX PROBLEM --
RalfOnEmby 0 Posted November 7, 2020 Posted November 7, 2020 Hi, I have the same problem with my Emby server running on Debian. I can confirm, installing the beta fixes the issue :)
