marciotoledo 1 Posted September 27, 2020 Posted September 27, 2020 I´m using Raspberry pi 4 B with Raspbian with a Samsung external HD with 1TB. I have installed Emby Server 4.5.0.50 and it runs well. But I can´t add library on external HD. I tried many ways to fill the Add Library field unsuccessfully. I tried enter the path manually or searching by the "lens" until the folder that I want. In this case: /media/pi/10F9-2FC8 or /media/pi/10F9-2FC8/series I know that I need to change the permissions of folders so: pi@raspberrypi:/media/pi $ sudo chmod 777 10F9-2FC8/ pi@raspberrypi:/media/pi $ ls -l total 64 drwxr-xr-x 7 pi pi 65536 Dec 31 1969 10F9-2FC8 It cannot change the "w" permission for group and all. But I think that´s not necessary because I´m using alone the server! So when I tried to add library I get the error: "The path could not be found. Please ensure the path is valid and try again." Someone can help me? Hugs!
mastrmind11 722 Posted September 27, 2020 Posted September 27, 2020 th entire folder structure of your mount needs to be accessible by emby, so check the permissions of the entire tree.
marciotoledo 1 Posted September 27, 2020 Author Posted September 27, 2020 (edited) I did: pi@raspberrypi:/media/pi $ sudo chmod -R 777 10F9-2FC8/ pi@raspberrypi:/media/pi $ ls -l total 64 drwxr-xr-x 7 pi pi 65536 Dec 31 1969 10F9-2FC8 and pi@raspberrypi:/media/pi/10F9-2FC8 $ sudo chmod -R 777 series/ and the error persists. Edited September 27, 2020 by marciotoledo
Luke 42246 Posted September 27, 2020 Posted September 27, 2020 Hi there, have you taken a look at our file permissions guide?
mark-in-dallas 87 Posted September 27, 2020 Posted September 27, 2020 (edited) Have you made the emby user a member of the pi group? sudo usermod -a -G pi emby Edited September 27, 2020 by mark-in-dallas
