Guest Posted September 27, 2020 Posted September 27, 2020 For some reason channel 12 and another appear before channel 3 which annoys the hell out of my OCD. I would love to be able to manually arrange my channels so the number sequences are correct. Not a huge deal just annoying.
Solution PenkethBoy 2068 Posted September 27, 2020 Solution Posted September 27, 2020 give each channels a sortname - then you can have them in any order you like
Red5ive 30 Posted October 7, 2020 Posted October 7, 2020 On 27/09/2020 at 07:41, PenkethBoy said: give each channels a sortname - then you can have them in any order you like Does this affect the sort order in the 'On Now' strip from the home screen?
ebr 16339 Posted October 7, 2020 Posted October 7, 2020 2 minutes ago, Red5ive said: Does this affect the sort order in the 'On Now' strip from the home screen? Definitely will in Android TV and Fire TV. Not sure if that has made it to the other apps.
