niallobr 9 Posted September 26, 2020 Posted September 26, 2020 (edited) Hi guys, First time poster so apologies in advance if this has already been highlighted or if it's the wrong place... couldn't find anything in my search. On Xbox One here's how my 1000x1500 posters are rendering: As you can see the poster isn't fitting the frame or vice versa (small gap below the image) but I think 1000x1500 is the recommended size? I tested with a 2000x3000 and a 1400x2100 image and these work. I think these are all a 2:3 aspect ratio. Here's how the same movie looks on iPadOS, poster is perfect. All poster sizes are working perfectly on this client. Any ideas? Attached the relevant poster just in case. Thanks for your continued work on Emby. It's a real breath of fresh air from Plex in many ways and was happy to get lifetime Premiere. Keep it up. Edited September 26, 2020 by niallobr
Happy2Play 9811 Posted September 26, 2020 Posted September 26, 2020 Yes I see this placeholder issue in app store Theater 1.1.314.0, but not desktop 3.0.12.
Luke 42240 Posted September 26, 2020 Posted September 26, 2020 Hi, this should be resolved with the next app update. Thanks.
Happy2Play 9811 Posted September 26, 2020 Posted September 26, 2020 Also this appears to be limited to TV Mode also.
niallobr 9 Posted September 26, 2020 Author Posted September 26, 2020 Damn, you guys are fast. Thanks for checking it out
Happy2Play 9811 Posted September 26, 2020 Posted September 26, 2020 Actually a scaling/resolution issue on placeholder.
niallobr 9 Posted September 27, 2020 Author Posted September 27, 2020 Just noticed this is happening on iPad in portrait orientation too This poster is 1000x1426.
Luke 42240 Posted September 28, 2020 Posted September 28, 2020 It's resolved for the next update to the iPad app. Thanks for the feedback.
SamuelWinsor 12 Posted October 8, 2020 Posted October 8, 2020 Just for reference, I’ve been having the exact same issue on XB1X Emby Theater for probably two months now. Otherwise runs as it should as far as I can tell.
Luke 42240 Posted October 8, 2020 Posted October 8, 2020 Just now, SamuelWinsor said: Just for reference, I’ve been having the exact same issue on XB1X Emby Theater for probably two months now. Otherwise runs as it should as far as I can tell. Hi, can you please show a screenshot to demonstrate? It should be resolved now in the latest update to the app. Thanks.
Happy2Play 9811 Posted October 8, 2020 Posted October 8, 2020 Just tested Emby for Windows v1.1.317.0 store version and appears to resolve the issue.
Luke 42240 Posted October 8, 2020 Posted October 8, 2020 2 minutes ago, Happy2Play said: Just tested Emby for Windows v1.1.317.0 store version and appears to resolve the issue. Thanks for the feedback !
SamuelWinsor 12 Posted October 10, 2020 Posted October 10, 2020 Hi Luke. Unfortunately I can’t get you a screenshot, because the issue is no longer happening on XBX1 for me. However, the posters for the film only (not actors etc) are now absolutely tiny. Will get a photo shortly if you’d like?
