sammyk77 1 Posted September 25, 2020 Posted September 25, 2020 I'm having issues with live TV timeshift. If I pause and then fast forward past the "live" point, it stops playback until I rewind behind the live point. And then the buffer that was there is gone. Plus, if I'm playing TV from the buffer and rewind, often after rewinding about 30 seconds, it will jump forward minutes. Then if I continue to press the rewind button, it will skip forward with each press, instead of skipping backwards. I want to buy the lifetime subscription, but honestly, these issues are making it frustratingly not as useful as I was expecting it to be. Please let me know if you need any more info. Thank you. embyserver.txt
Sammy 791 Posted September 25, 2020 Posted September 25, 2020 I've noticed this too but haven't had the time to post it yet. You should also mention what client you're using and post those logs too. Next time I encounter it I'll post mine too.
sammyk77 1 Posted September 25, 2020 Author Posted September 25, 2020 I'm using Emby Theater for Windows.
sammyk77 1 Posted September 30, 2020 Author Posted September 30, 2020 This seems to only be an issue with Emby Theater. What other info do I need to provide?
Luke 42240 Posted October 3, 2020 Posted October 3, 2020 Hi there, yes this is something that we need to look at in the app. Thanks for reporting.
