quickmic 1709 Posted September 24, 2020 Posted September 24, 2020 (edited) 2020-09-24 21:32:33.124 Info HttpClient: GET https://api.themoviedb.org/3/tv/28290?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,keywords,external_ids,videos,content_ratings&language=en&include_image_language=en,null 2020-09-24 21:32:33.153 Error App: Error in TheMovieDb *** Error Report *** Version: 4.5.0.29 Command line: /opt/emby/EmbyServer.dll Operating system: Linux version 5.4.55-1-pve (root@nora) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP PVE 5.4.55-1 (Mon, 10 Aug 2020 10:26:27 +0200) Framework: .NET Core 3.1.8 OS/Process: x64/x64 Runtime: usr/share/dotnet/shared/Microsoft.NETCore.App/3.1.8/System.Private.CoreLib.dll Processor count: 12 Data path: /opt/programdata Application path: /opt/emby System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at MovieDb.MovieDbSeriesProvider.GetMetadata(SeriesInfo info, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: MovieDb TargetSite: Void MoveNext() 2020-09-24 21:32:33.153 Debug App: Running OmdbItemProvider for /mnt/storage1/series/E/Engineering Connections Please let me know, if additional info are required. Thanks Edited September 24, 2020 by quickmic
Happy2Play 9802 Posted September 24, 2020 Posted September 24, 2020 (edited) All that error is telling you is there is no TV show with id 28290 on their site. Do you know what show it is? Is it "Engineering Connections"? But I am just guessing either external id changed or is just wrong. Only see a movie with that id not any shows. Edited September 24, 2020 by Happy2Play
quickmic 1709 Posted September 24, 2020 Author Posted September 24, 2020 Well, the problem is not that the show is not available in TheMovieDB. The problem is, that emby has a problem with the answer from TheMovieDB and raises an exception?
Luke 42210 Posted September 24, 2020 Posted September 24, 2020 No I think you have an Id saved in your metadata that over time has become invalid (e.g. was removed from MovieDb). 1
Happy2Play 9802 Posted September 24, 2020 Posted September 24, 2020 1 minute ago, quickmic said: Well, the problem is not that the show is not available in TheMovieDB. The problem is, that emby has a problem with the answer from TheMovieDB and raises an exception? Well the id in your metadata is wrong for the show and return a error as that id does not exist. Have you compared the id on TMDB to the external id that is in your metatadata? Is it not suppose to be 7905? if not can you provide a like to the show. 1
quickmic 1709 Posted September 24, 2020 Author Posted September 24, 2020 I updated the ID manually, no more issue for that show but I have a view more with the same problem. I'll update them as well. Thanks for you help.
