CHA0SENG7NE 28 Posted September 26, 2020 Author Posted September 26, 2020 4 minutes ago, PenkethBoy said: i just want use to try and get a closer approx similar setup as we can if it does not happen with 2017 - then you have your answer its a Nvidia firmware issue - or at least related That would be a shocker if that was the cause
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 yep the 70+ is an average not a real max
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 Nope - Nvidia make mistake like Emby
vdatanet 1619 Posted September 26, 2020 Posted September 26, 2020 Related to this, when we add a folder to a library we can indicate the path of the shared folder, so that in a local environment with direct play, the path can be used instead of http streaming. What clients support this?
rbjtech 5337 Posted September 26, 2020 Posted September 26, 2020 3 minutes ago, vdatanet said: Related to this, when we add a folder to a library we can indicate the path of the shared folder, so that in a local environment with direct play, the path can be used instead of http streaming. What clients support this? A good question - if we can use this, then the problem is eliminated ! You can use this via the Android client if you specify to use an External player/setup the direct access permissions (did this earlier today, works fine with VLC as the player - played 1918 4K fine) but then of course you lose all the Emby on-screen features..
vdatanet 1619 Posted September 26, 2020 Posted September 26, 2020 https://support.emby.media/support/solutions/articles/44001159320-optional-network-paths Quote This will allow some Emby apps to access the media directly and avoid having to stream or transcode using Emby Server. It would be interesting to know what are those some Emby apps.
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 i have done an initial test by adding a new library to my test server with the two movie my server is win 10 if that matters i added the library path as unc to start with to see what results we get Played Alita first - initially the network was doing about 25 MB/s - initial couple of bumps on the network trace - then a few mins in this flat lined at approx 8MB/s cpu approx 20% and MS Networking SMB 6% cpu Not pausing or stuttering Then tried 1917 1917 starts from the drop to zero on left side was expecting the trace to jump up as the shield caches the movie (or part of it) as i thought it did for Alita - but that could be emby as just added a new library for it to process on ATV but now it just went back 7-8MB/s Initially it plays fine then pauses for a few seconds every 1 min or so - its not unwatchable - just annoying No point trying anything else - its not the QNAP as its hardly breaking sweat and my test pc is not involved as using the unc path the shield can access the file directly so either the Emby ATV app or the Shield are the smoking gun for me Shield App 33g
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 12 minutes ago, rbjtech said: A good question - if we can use this, then the problem is eliminated ! You can use this via the Android client if you specify to use an External player/setup the direct access permissions (did this earlier today, works fine with VLC as the player - played 1918 4K fine) but then of course you lose all the Emby on-screen features.. Nice idea but i deliberately used a unc path for my first of my planned several test but the pausing does occur even with a UNC path (only path added to library) so no more test necessary
CBers 7542 Posted September 26, 2020 Posted September 26, 2020 5 minutes ago, PenkethBoy said: No point trying anything else - its not the QNAP as its hardly breaking sweat and my test pc is not involved as using the unc path the shield can access the file directly So if you shut down your Emby server, does playback continue?
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 it does for 30 seconds then stops on ATV My test pc has netrok traffic of no more than 100kb/s - as i am reading frourms like this but 100% not involved directly in data to shield just a hand shake / keep alive or similar - that atv detects after 30 sec has gone so stops playback i guess would have expected it to continue till end of movie - then have a strop as cant see server - but maybe its expected not tried before
CBers 7542 Posted September 26, 2020 Posted September 26, 2020 1 minute ago, PenkethBoy said: would have expected it to continue till end of movie Me too.
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 drop to zero one - me manually stopping 1917 then me playing Alita again drop to zero two - me turning of emby server then my playing alita again after turning server back on Interestingly ATV did not complain to the user - logs might be different though 1
CHA0SENG7NE 28 Posted September 26, 2020 Author Posted September 26, 2020 22 minutes ago, PenkethBoy said: i have done an initial test by adding a new library to my test server with the two movie my server is win 10 if that matters i added the library path as unc to start with to see what results we get Played Alita first - initially the network was doing about 25 MB/s - initial couple of bumps on the network trace - then a few mins in this flat lined at approx 8MB/s cpu approx 20% and MS Networking SMB 6% cpu Not pausing or stuttering Then tried 1917 1917 starts from the drop to zero on left side was expecting the trace to jump up as the shield caches the movie (or part of it) as i thought it did for Alita - but that could be emby as just added a new library for it to process on ATV but now it just went back 7-8MB/s Initially it plays fine then pauses for a few seconds every 1 min or so - its not unwatchable - just annoying No point trying anything else - its not the QNAP as its hardly breaking sweat and my test pc is not involved as using the unc path the shield can access the file directly so either the Emby ATV app or the Shield are the smoking gun for me Shield App 33g This is exactly what I have been suffering. Good to see it can be replicated.
sooty234 266 Posted September 26, 2020 Posted September 26, 2020 So what are we thinking, here? The server is getting in the way of truly direct playing?
CBers 7542 Posted September 26, 2020 Posted September 26, 2020 5 minutes ago, CHA0SENG7NE said: This is exactly what I have been suffering. Good to see it can be replicated. Do you have another Emby client you can use? Just wondering if it's exoplayer. TL;DR Have you tried an external player?
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 12 minutes ago, sooty234 said: So what are we thinking, here? The server is getting in the way of truly direct playing? No i dont think so but there appears to be some communication between the server and the client - handshake/update progress - opposite to the client being shutdown by a user but did not stop playback - or similar Just going to try from my 2012r2 server for same files with its unc path and see if results are different or not
FrostByte 5437 Posted September 26, 2020 Posted September 26, 2020 I started a movie with ATV and selected VLC as an external player while passing the direct path. Then I shutdown Emby server. I'm about 15 minutes in right now so assume it's direct playing because Emby server is down now
sooty234 266 Posted September 26, 2020 Posted September 26, 2020 2 minutes ago, PenkethBoy said: No i dont think so but there appears to be some communication between the server and the client - handshake/update progress - opposite to the client being shutdown by a user but did not stop playback - or similar Just going to try from my 2012r2 server for same files with its unc path and see if results are different or not Oh right, of course there is. Playback position among other things. To allow resuming. 1
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 yep but if server dies then that could be kept local until server comes back even if ATV closed etc etc and several days later But this is emby i guess
CBers 7542 Posted September 26, 2020 Posted September 26, 2020 @CHA0SENG7NE Have you tried the AET app on your Shield? https://emby.media/community/index.php?/topic/88485-emby-for-android-3124-testing/ 1
CHA0SENG7NE 28 Posted September 26, 2020 Author Posted September 26, 2020 28 minutes ago, CBers said: Do you have another Emby client you can use? Just wondering if it's exoplayer. TL;DR Have you tried an external player? I can use a decent Pc with emby theater if that's a help?
CHA0SENG7NE 28 Posted September 26, 2020 Author Posted September 26, 2020 31 minutes ago, CBers said: Do you have another Emby client you can use? Just wondering if it's exoplayer. TL;DR Have you tried an external player? I'm testing using VLC as external player to see now.....
CHA0SENG7NE 28 Posted September 26, 2020 Author Posted September 26, 2020 13 minutes ago, CBers said: @CHA0SENG7NE Have you tried the AET app on your Shield? https://emby.media/community/index.php?/topic/88485-emby-for-android-3124-testing/ I have only tried the version available from the play store. So this is different to that. I'm happy to give it a try and report back
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 Ok - just tried playing from my 2012r2 server - same setup as the NAS only diff was unc path was different to copies of the same files So nothing to do with a NAS Some weird bug for @ebr to look at Oh and if i turn off the server with 2012r2 as source - ATV stops playback after 20-30 seconds
PenkethBoy 2068 Posted September 26, 2020 Posted September 26, 2020 as a final couple of tests I mapped the unc path to the remote drive - still pauses But if i use my normal server (beta) which has the movies on local drives - NO Pauses
