OlishaDoon 0 Posted October 1, 2020 Posted October 1, 2020 11 hours ago, CHA0SENG7NE said: I have it working now... Finally stream type: file Just played 15 mins without a hiccup. Thank you Can You, please, mark what have You done to fix it?
vdatanet 1619 Posted October 1, 2020 Posted October 1, 2020 (edited) 34 minutes ago, OlishaDoon said: Can You, please, mark what have You done to fix it? Enabling direct file playback on Nvidia Shield. A wiki article is on the way. In short: 1. Install Android TV beta .36 2. Enable direct file playback in settings (Android TV app) 3. Mount your network storage in Nvidia Shieldhttps://nvidia.custhelp.com/app/answers/detail/a_id/4836/~/how-do-i-share-pc-folders-with-shield 4. Check the mount point name in Nvidia Shield 5. Make sure the Emby library path matches the mount point name in Nvidia Shield. You can use the alternate path. Be careful, that route is case sensitive: If your Nvidia Shield mount point is /storage/YOURSERVER/Your_SharE/ your library path or alternative path must be \\YOURSERVER\Your_SharE During playback, check SFN (Stats for Nerds). Look at the protocol, http or file Edited October 1, 2020 by vdatanet 4
vdatanet 1619 Posted October 1, 2020 Posted October 1, 2020 3 hours ago, cayars said: That's the point vdatanet, the hardware DOES NOT support it, nor is there any real life sources of this content available unless you're shooting and producing it yourself! 160 Mbps is higher than you're going to be able to use already. It's essentially "unlimited" already. Other devices that run this app are going to likely be far lower than the Shield TV as it's the current Media beast for streaming. The Devs could change 160 Mbps to "Unlimited" but it will not change what the device can play as it can't reach 160 Mbps. I am not in favor of setting limits with the argument that this content is unusual. I do not see so crazy that the current hardware can support that, my wallet sure not, but others...
rbjtech 5337 Posted October 1, 2020 Posted October 1, 2020 I think this thread has gone a bit off topic tbh and that discussion should probably go into 'General Discussion' but I completely agree with @cayars If you have access to uncompressed masters, good for you - but don't expect a product designed for commercially available media to play them. 1
OlishaDoon 0 Posted October 1, 2020 Posted October 1, 2020 2 hours ago, vdatanet said: Enabling direct file playback on Nvidia Shield. A wiki article is on the way. In short: 1. Install Android TV beta .36 2. Enable direct file playback in settings (Android TV app) 3. Mount your network storage in Nvidia Shieldhttps://nvidia.custhelp.com/app/answers/detail/a_id/4836/~/how-do-i-share-pc-folders-with-shield 4. Check the mount point name in Nvidia Shield 5. Make sure the Emby library path matches the mount point name in Nvidia Shield. You can use the alternate path. Be careful, that route is case sensitive: If your Nvidia Shield mount point is /storage/YOURSERVER/Your_SharE/ your library path or alternative path must be \\YOURSERVER\Your_SharE During playback, check SFN (Stats for Nerds). Look at the protocol, http or file Thank You, Sir
Luke 42208 Posted October 4, 2020 Posted October 4, 2020 Would you mind trying the 4.6.0.2 beta server to see how it compares? Thanks. 1
CHA0SENG7NE 28 Posted October 6, 2020 Author Posted October 6, 2020 (edited) I have tried the latest atv app 38g and server 4.6.0.2 Set library to just standard IP address of media. Played some 4k remux files. It's working perfectly. Stream type is http. HDR works Atmos and DTS X works Takes 3 seconds to play Windows server. Qnap media Network storage isnt mounted in shield Amazing job. Edited October 6, 2020 by CHA0SENG7NE 3
Solution Luke 42208 Posted October 6, 2020 Solution Posted October 6, 2020 thanks for the feedback. We'll be putting out a 4.5.2 server update with the performance fix. Thanks. 1
CHA0SENG7NE 28 Posted October 6, 2020 Author Posted October 6, 2020 It literally just works without any effort. Just tried on another shield.. same again. Worked first time. Plays smoothly.
CHA0SENG7NE 28 Posted October 6, 2020 Author Posted October 6, 2020 1 minute ago, Luke said: thanks for the feedback. We'll be putting out a 4.5.2 server update with the performance fix. Thanks. Thanks for all the help on this thread. It's been amazing. Everyone chipping in with ideas and solutions. It's an excellent community of clever people and very patient. The end result is a fix and easy setup for the end user. Once the stable release is out I will switch over from my qnap to the windows server. Happy days. 4
rbjtech 5337 Posted October 7, 2020 Posted October 7, 2020 @CHA0SENG7NE - could you also mark Luke's Beta response with 'best answer' - as it's a long thread and other people will likely want to jump directly to the answer 1
CBers 7542 Posted October 7, 2020 Posted October 7, 2020 1 minute ago, CHA0SENG7NE said: Sure, how? Click the TICK to the left of the relevant post. 1
