Carlo 4561 Posted September 30, 2020 Posted September 30, 2020 54 minutes ago, CHA0SENG7NE said: On a hunch leave that mount there but add one using your IP as shown in the picture above 192.168.0.160. Since that is a UNC mount already the Shield may never get your OPTIONAL mount point and may be looking for a mount name "192.168.0.160" Worth a test!
FrostByte 5437 Posted September 30, 2020 Posted September 30, 2020 57 minutes ago, CHA0SENG7NE said: When I click into this it's shows the shared folders. I looks like it's still scanning (calculating) your shares. See if it's still a problem after i's done
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 I waited and it made no difference.
Carlo 4561 Posted September 30, 2020 Posted September 30, 2020 I think you're issue is you're not matching the UNC. You're library mount in Emby was 192.168.0.160 but I don't see that name as a mount above. If you go to a movie in your library, go to the detail screen, scroll down to the bottom. What does it show for the path?
ebr 16310 Posted September 30, 2020 Posted September 30, 2020 9 hours ago, CHA0SENG7NE said: This is how I have it 3 hours ago, CHA0SENG7NE said: Linux file systems are case-sensitive. Try changing your optional network path to match...
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 Thanks cayars. It's most likely something I'm doing wrong. This is the movie detail.
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 1 minute ago, ebr said: Linux file systems are case-sensitive. Try changing your optional network path to match... I actually tried it!.... it didn't work.
CBers 7542 Posted September 30, 2020 Posted September 30, 2020 Also, use a file manager on your Shield, such as X-Plore, to see if the Shield sees the shares.
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 Ok so to be clear should I change the library from the \\192.168.0.160\Multimedia\4K Movies To \\QNAP-TS653A\Multimedia \4K Movies I have just tested with x-plore app CBers the shield see the shares. They have the location shown as this... /storage/QNAP-TS653A/MULTIMEDIA/4K Movies 1
ebr 16310 Posted September 30, 2020 Posted September 30, 2020 16 minutes ago, CHA0SENG7NE said: Ok so to be clear should I change the library from the \\192.168.0.160\Multimedia\4K Movies To \\QNAP-TS653A\Multimedia \4K Movies I have just tested with x-plore app CBers the shield see the shares. They have the location shown as this... /storage/QNAP-TS653A/MULTIMEDIA/4K Movies Okay, so assuming that the space in the server path you setup is a typo, can you please change that to: \\QNAP-TS653A\MULTIMEDIA\4K Movies and then try it...?
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 1 minute ago, ebr said: Okay, so assuming that the space in the server path you setup is a typo, can you please change that to: \\QNAP-TS653A\MULTIMEDIA\4K Movies and then try it...? Sorry it is correct, that's just my lazy ass typing on a phone
ebr 16310 Posted September 30, 2020 Posted September 30, 2020 Just now, CHA0SENG7NE said: Sorry it is correct, that's just my lazy ass typing on a phone What is the path/share name in the actual file system (on the NAS)?
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 5 minutes ago, ebr said: What is the path/share name in the actual file system (on the NAS)? I have no idea how to get that I have always just used the network icon and clicked on the qnap map which shows the shared folders (within windows) That path is \\QNAP-TS653a\Multimedia\Movies\4K Movies
vdatanet 1619 Posted September 30, 2020 Posted September 30, 2020 1 minute ago, CHA0SENG7NE said: I have no idea how to get that I have always just used the network icon and clicked on the qnap map which shows the shared folders (within windows) That path is \\QNAP-TS653a\Multimedia\Movies\4K Movies
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 If i look on the qnap server which uses the direct paths on the qnap they are /share/CACHEDEV1_DATA/Multimedia/Movies/4K Movies
vdatanet 1619 Posted September 30, 2020 Posted September 30, 2020 Just now, CHA0SENG7NE said: If i look on the qnap server which uses the direct paths on the qnap they are /share/CACHEDEV1_DATA/Multimedia/Movies/4K Movies You have to know the mounting point in Nvidia Shield: Mounting point: /storage/YOURSERVER/YOURSHARE Alternative path in Emby: \\YOURSERVER\YOURSHARE 1
rbjtech 5337 Posted September 30, 2020 Posted September 30, 2020 Guys - take a look at the Beta thread - the CASE of the share name is very important, and must exactly match what you have in Emby. ie \\server\<share_name>\ in emby will NOT work as the Android TV maps it locally to \\SERVER\<share_name\ ! So you need to change your UNC paths to match, and rescan I'm afraid ...
vdatanet 1619 Posted September 30, 2020 Posted September 30, 2020 Just now, rbjtech said: Guys - take a look at the Beta thread - the CASE of the share name is very important, and must exactly match what you have in Emby. ie \\server\<share_name>\ in emby will NOT work as the Android TV maps it locally to \\SERVER\<share_name\ ! So you need to change your UNC paths to match, and rescan I'm afraid ... There's no need to rescan, just set the alternative network path in the Library.
vdatanet 1619 Posted September 30, 2020 Posted September 30, 2020 (edited) 1 minute ago, CHA0SENG7NE said: Your alternative path should be \\QNAP-TS653A\Multimedia Edited September 30, 2020 by vdatanet 1
CHA0SENG7NE 28 Posted September 30, 2020 Author Posted September 30, 2020 Just now, vdatanet said: Your alternative path should be \\QNAP-TS653A\Public Why would it be public?
vdatanet 1619 Posted September 30, 2020 Posted September 30, 2020 Just now, CHA0SENG7NE said: Why would it be public? Multimedia 1
rbjtech 5337 Posted September 30, 2020 Posted September 30, 2020 (edited) 8 minutes ago, vdatanet said: There's no need to rescan, just set the alternative network path in the Library. Ah of course - basically have both \\media\<share_name> \\MEDIA\<share_name> in the optional field. I will test that now ... I wasn't looking forward to rescanning everything .. Edited September 30, 2020 by rbjtech
Carlo 4561 Posted September 30, 2020 Posted September 30, 2020 I think you'll be set now once you get the case correct.
