Robert_84 4 Posted October 11, 2020 Posted October 11, 2020 after the reinstall files are scanned but no metadata is downloaded at all embyserver.txt ffmpeg-transcode-feafcd4d-65e7-4536-a36b-614107f19e8c_1.txt
Happy2Play 9812 Posted October 11, 2020 Posted October 11, 2020 (edited) 39 minutes ago, Robert_84 said: after the reinstall files are scanned but no metadata is downloaded at all embyserver.txt 20.25 MB · 0 downloads ffmpeg-transcode-feafcd4d-65e7-4536-a36b-614107f19e8c_1.txt 30.84 kB · 0 downloads Please post a server log from restart not a midnight rollover log as it does not show the plugin loading process. But can assume plugin permissions as you have no provider plugins installed. 2020-10-11 00:00:00.025 Info App: Plugins: Bluray Folder Support 1.0.0.0 Dlna 1.0.40.0 Dvd Folder Support 1.0.0.0 Fanart.tv 1.0.10.0 MusicBrainz 1.0.13.0 Open Subtitles 1.0.27.0 Port Mapper 1.0.4.0 Studio Images 1.0.3.0 Webhooks 1.0.13.0 Edited October 11, 2020 by Happy2Play
Robert_84 4 Posted October 11, 2020 Posted October 11, 2020 "server log" ?? I added "first" log available after the update. "020-10-11 00:00:00.025 Info App: Plugins:" Bluray Folder Support 1.0.0.0 Dlna 1.0.40.0 Dvd Folder Support 1.0.0.0 Fanart.tv 1.0.10.0 MusicBrainz 1.0.13.0 Open Subtitles 1.0.27.0 Port Mapper 1.0.4.0 Studio Images 1.0.3.0 Webhooks 1.0.13.0 I have no idea abut plugins. I only know this. While I was fixing with "the Synology dev team" 4k transecoding on full hd tv. Transecoding was fixed, but in the meanwihile something else was broken. Also I see many others are having differant metadata problems on the forum it is not just an isolated problem. embyserver-63737884800.txt embyserver-63737798400.txt
Luke 42243 Posted October 11, 2020 Posted October 11, 2020 Can you try shutting down the server, then deleting this folder: /volume1/Emby/plugins Then start up the server and attach the new server log. thanks.
Happy2Play 9812 Posted October 11, 2020 Posted October 11, 2020 35 minutes ago, Robert_84 said: "server log" ?? I added "first" log available after the update. But all of these current logs are not from startup they are midnight rollover logs. 2020-10-11 00:00:00.023 Info App: Application version: 4.6.0.2 2020-10-09 00:00:00.001 Info App: Application version: 4.6.0.2 2020-10-08 00:00:00.065 Info App: Application version: 4.6.0.2 38 minutes ago, Robert_84 said: Also I see many others are having differant metadata problems on the forum it is not just an isolated problem. And not everyone is having the exact same permissions issues, but yes this new way has created issues for some but not all Synology users.
Robert_84 4 Posted October 12, 2020 Posted October 12, 2020 (edited) 15 hours ago, Luke said: Can you try shutting down the server, then deleting this folder: /volume1/Emby/plugins Then start up the server and attach the new server log. thanks. I hope this is it, I have folder arranged different little bit. I deleted Plugins folder from the drive below, it is actually where the Emby is installed hardware_detection-63738118284.txt embyserver (1).txt Edited October 12, 2020 by Robert_84 update 1
Robert_84 4 Posted October 12, 2020 Posted October 12, 2020 Now I have this after plg is deleted Maybe now it will work
Luke 42243 Posted October 12, 2020 Posted October 12, 2020 Thanks for the feedback. Apologies for the disruption.
