Luke 42243 Posted September 28, 2020 Posted September 28, 2020 Did you do it within the last three hours?
Robert_84 4 Posted September 28, 2020 Posted September 28, 2020 5 minutes ago, Luke said: Did you do it within the last three hours? last time I did it at 21:55, firs time it was little bit early when U first informed me can I tried it. so last try was in last 30 min
Robert_84 4 Posted September 28, 2020 Posted September 28, 2020 9 minutes ago, Happy2Play said: Your plugins still have a Permissions issue. System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/volume1/Emby/plugins/MovieDb.dll' is denied. then I need to give Permissions to whitch user emby or embysrv or other system users
Robert_84 4 Posted September 28, 2020 Posted September 28, 2020 he already have full access to all emby folders, no I added access to one additional user, and now Im checking
Robert_84 4 Posted September 28, 2020 Posted September 28, 2020 rescan metadata update, all images replace and missing images search
Luke 42243 Posted September 28, 2020 Posted September 28, 2020 I meant regarding the user permissions?
Robert_84 4 Posted September 28, 2020 Posted September 28, 2020 (edited) assigned permissions to the user emby after the update user emby was without access to Emby "folder". then I manually assigned access to him. visible on the images below Edited September 28, 2020 by Robert_84 update 1
Robert_84 4 Posted September 28, 2020 Posted September 28, 2020 (edited) should i delete user embysvr Edited September 28, 2020 by Robert_84 edit name
Luke 42243 Posted September 29, 2020 Posted September 29, 2020 Please try Emby Server 4.5.1 and see if that helps. thanks.
Robert_84 4 Posted September 30, 2020 Posted September 30, 2020 Hi, Synology is not allowing me to rollback to an older version
Luke 42243 Posted September 30, 2020 Posted September 30, 2020 1 hour ago, Robert_84 said: Hi, Synology is not allowing me to rollback to an older version Can you Please try the new Emby Server 4.5.1 release and see if that helps. thanks.
Robert_84 4 Posted September 30, 2020 Posted September 30, 2020 (edited) Sorry but I cant install 4.5.1 over 4.6.1, Synology is not allowing it. Edited September 30, 2020 by Robert_84
Robert_84 4 Posted September 30, 2020 Posted September 30, 2020 if it is new version why not name it with the higher number?
Luke 42243 Posted September 30, 2020 Posted September 30, 2020 4.5.1 is greater than 4.5.0. I didn't realize you're on the beta server.
Robert_84 4 Posted September 30, 2020 Posted September 30, 2020 no worry I posted a many posts, hard to track everything.
alucryd 318 Posted October 9, 2020 Posted October 9, 2020 The embysvr user should have been deleted when you upgraded to our new package. In any case you can get rid of it now. As for the permissions, they should be corrected by reinstalling the latest beta, please try that and please don't modify the permissions of the Emby shared folder.
Robert_84 4 Posted October 9, 2020 Posted October 9, 2020 hi, svr is already deleted, and im already on 4.6.0.2 but the proble mis not resolved. also if I do not add ready/write permissions to the Emby 10TB folder I cant watch the movies. Becasue they are in that folder. However how "Allow" permissions to read something can affect something like this.
Luke 42243 Posted October 11, 2020 Posted October 11, 2020 If you reinstall 4.6.0.2 from the website on top of your existing installation, does that help?
Robert_84 4 Posted October 11, 2020 Posted October 11, 2020 hi, I already have the lastest beta release, I do not believe new reinstallation will resolve the problem, but Ill try
Luke 42243 Posted October 11, 2020 Posted October 11, 2020 We have made some adjustments to the package, can you please give it a try? thanks.
Robert_84 4 Posted October 11, 2020 Posted October 11, 2020 I did, it is "reimporting" entire folder.... ill let you know the result... I seen now the www is also better organized ...
Luke 42243 Posted October 11, 2020 Posted October 11, 2020 Great, let us know how you get on. Thanks.
