ebr 16337 Posted February 17, 2021 Posted February 17, 2021 Hi. There was no playback in the log you sent. You need to send the log immediately after stopping playback and only play for a few seconds. However, it sounds like maybe your equipment doesn't support DTS HRA...
CyberPoison 33 Posted February 17, 2021 Posted February 17, 2021 58 minutes ago, ebr said: Hi. There was no playback in the log you sent. You need to send the log immediately after stopping playback and only play for a few seconds. However, it sounds like maybe your equipment doesn't support DTS HRA... It works fine with VLC as third external player. let me just send a other log report
CyberPoison 33 Posted February 17, 2021 Posted February 17, 2021 (edited) Just sent a other now, at 16:20 gmt +1 Paris Time, please let me know if everything is ok, from my side the audio in HRA 7.1 on my Onkyo only works from VLC media player, as proof there is some photos of the output, As you can see my AV support it. It is maybe a issue with the exoplayer it need to be checked no sure can you try it with your AV and tell me if it supports HRA 7.1 btw tell me or send me a PM's if you have some issue from the log like no playback on logs or etc... Kind regards Check also logs at 16:33 gmt+1 Paris Time Movie Jurrasic Park & Pirates of Caribbean (HRA 5.1 NO audio also) Logs sent at 16:39 gmt +1 Paris Time Edited February 17, 2021 by CyberPoison
ebr 16337 Posted February 17, 2021 Posted February 17, 2021 The other user with this issue said HRA was working for them now. In reality, Exo doesn't completely support DTS-HD at all but we are "tricking" it into doing it. It is possible it doesn't work in all situations but it did work for the other user. Unfortunately, I cannot see any playback in your logs. Not your fault. It is just Android not providing us the information.
CyberPoison 33 Posted February 18, 2021 Posted February 18, 2021 11 hours ago, ebr said: The other user with this issue said HRA was working for them now. In reality, Exo doesn't completely support DTS-HD at all but we are "tricking" it into doing it. It is possible it doesn't work in all situations but it did work for the other user. Unfortunately, I cannot see any playback in your logs. Not your fault. It is just Android not providing us the information. When Android will give you the playback logs again just tell me a will send a new logs about it, do you want a sample file to test it? Or you have some MKV and MP4 dts hra 7.1 & 5.1 files?
CyberPoison 33 Posted April 27, 2021 Posted April 27, 2021 (edited) On 2/17/2021 at 11:49 PM, ebr said: The other user with this issue said HRA was working for them now. In reality, Exo doesn't completely support DTS-HD at all but we are "tricking" it into doing it. It is possible it doesn't work in all situations but it did work for the other user. Unfortunately, I cannot see any playback in your logs. Not your fault. It is just Android not providing us the information. I tested the movie today it was working nice, maybe the update have some code. but it's work I tested the movie but it say dts hra 5.1 on the AV audio Receiver instead of 7.1 but with the vlc and the passthrought it works i will send a sample so you can test Edited April 27, 2021 by CyberPoison
Katzenfutter 0 Posted December 11, 2021 Posted December 11, 2021 I have a similar issue... An .mkv file with "DTS-HR 5.1" Track only appears as "DTS" on my Receiver. (played on the latest emby stable Version from Play Store on my Shield TV Pro 2019) When I'm playing the same file via Kodi, it shows DTS-HR in the display of my receiver. What can I do about that?
ebr 16337 Posted December 12, 2021 Posted December 12, 2021 18 hours ago, Katzenfutter said: I have a similar issue... An .mkv file with "DTS-HR 5.1" Track only appears as "DTS" on my Receiver. (played on the latest emby stable Version from Play Store on my Shield TV Pro 2019) When I'm playing the same file via Kodi, it shows DTS-HR in the display of my receiver. What can I do about that? Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
MrMackey 35 Posted April 6, 2022 Posted April 6, 2022 (edited) Hey guys, I also have the same problem... when I watch on my Shield pro 2019 movies with DTS-HD HRA audio track, they are only output with DTS to the AVR. I played 2 movies for 10 sec. hope the log is helpful Dolby Atmos, DTS HD MSTR, Dolby True HD etc... otherwise works fine. embyserver.txt Edited April 6, 2022 by MrMackey
FrostByte 5454 Posted April 6, 2022 Posted April 6, 2022 32 minutes ago, MrMackey said: Hey guys, I also have the same problem... when I watch on my Shield pro 2019 movies with DTS-HD HRA audio track, they are only output with DTS to the ARV. I played 2 movies for 10 sec. hope the log is helpful Dolby Atmos, DTS HD MSTR, Dolby True HD etc... otherwise works fine. embyserver.txt 133.14 kB · 1 download Did you also send an app log to ebr?
MrMackey 35 Posted April 6, 2022 Posted April 6, 2022 2 minutes ago, FrostByte said: Did you also send an app log to ebr? No only this. I dont know how.
FrostByte 5454 Posted April 6, 2022 Posted April 6, 2022 25 minutes ago, MrMackey said: No only this. I dont know how. Enable Debug under General Display settings Play your movie with HRA bring up the OSD Click the cog wheel and then "Seng Logs"
FrostByte 5454 Posted April 6, 2022 Posted April 6, 2022 22 minutes ago, MrMackey said: thank you! done Forgot to say, you will need to let him know the time you sent the log and the user who was logged on 1
MrMackey 35 Posted April 6, 2022 Posted April 6, 2022 (edited) no problem thanks again user: stephan time: approximately 08:35 pm UTC-5 Edited April 6, 2022 by MrMackey 1
rbjtech 5344 Posted April 6, 2022 Posted April 6, 2022 Other than a couple of demo's - I've never seen DTS HR being used as a popular format. As far as I am aware, it's effectively Dolby Digital Plus in the DTS world - ie it's lossy and sits inbetween DTS and DTS HD:MA ? When I play the demo's on my Shield, my Denon AVR recognizes them as DTS-HR (it says so on the display) but they are corrupt and the sound breaks up. If I try and play with VLC as an external player, they 'play' but I think VLC is converting them to PCM as the AVR just says 'Multichannel' - not DTS-HR. Are the files you have definitely DTS-HR ? What does MediaInfo say about them ? 1
ebr 16337 Posted April 6, 2022 Posted April 6, 2022 10 hours ago, MrMackey said: no problem thanks again user: stephan time: approximately 08:35 pm UTC-5 Hi. The player/device only sees it as DTS. Can you hear a difference? 1
MrMackey 35 Posted April 6, 2022 Posted April 6, 2022 (edited) Yes I know that format is rare. I also think I only have max 10 movies with DTS-HR. Yes it really is DTS-HR. I create my files only with makeMKV and do not edit them in any other way. When I play it with VLC it is recognized correctly. Spoiler Format : Matroska Format version : Version 2 File size : 21.5 GiB Duration : 1 h 41 min Overall bit rate mode : Variable Overall bit rate : 30.2 Mb/s Movie name : Requiem for a Dream Encoded date : UTC 2021-06-22 12:01:04 Writing application : MakeMKV v1.16.3 win(x64-release) Writing library : libmakemkv v1.16.3 (1.3.10/1.5.2) win(x64-release) Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 41 min Bit rate mode : Variable Bit rate : 26.1 Mb/s Maximum bit rate : 36.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.525 Stream size : 18.5 GiB (86%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Original source medium : Blu-ray Audio #1 ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS XBR Format/Info : Digital Theater Systems Commercial name : DTS-HD High Resolution Audio Codec ID : A_DTS Duration : 1 h 41 min Bit rate mode : Constant Bit rate : 2 046 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.45 GiB (7%) Title : Surround 5.1 Language : German Default : Yes Forced : No Original source medium : Blu-ray Audio #2 ID : 3 ID in the original source medium : 4353 (0x1101) Format : DTS XBR Format/Info : Digital Theater Systems Commercial name : DTS-HD High Resolution Audio Codec ID : A_DTS Duration : 1 h 41 min Bit rate mode : Constant Bit rate : 2 046 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.45 GiB (7%) Title : Surround 5.1 Language : English Default : No Forced : No Original source medium : Blu-ray Text ID : 4 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 36 min Bit rate : 41.1 kb/s Count of elements : 1566 Stream size : 28.4 MiB (0%) Language : German Default : Yes Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : en:Chapter 01 00:08:08.321 : en:Chapter 02 00:15:45.152 : en:Chapter 03 00:21:24.408 : en:Chapter 04 00:27:49.334 : en:Chapter 05 00:33:09.988 : en:Chapter 06 00:38:08.160 : en:Chapter 07 00:47:18.836 : en:Chapter 08 00:51:48.063 : en:Chapter 09 00:53:19.821 : en:Chapter 10 00:56:38.645 : en:Chapter 11 01:05:07.528 : en:Chapter 12 01:08:42.409 : en:Chapter 13 01:17:56.171 : en:Chapter 14 01:29:02.211 : en:Chapter 15 01:37:36.183 : en:Chapter 16 Interesting in stats for nerds it is recognized as DTS-HD. Edited April 6, 2022 by MrMackey new picture 1
rbjtech 5344 Posted April 6, 2022 Posted April 6, 2022 15 minutes ago, MrMackey said: When I play it with VLC it is recognized correctly. Is that VLC direct or VLC via Emby ?
MrMackey 35 Posted April 6, 2022 Posted April 6, 2022 Just now, rbjtech said: Is that VLC direct or VLC via Emby ? this is emby with vlc as player. but it works also if you start only vlc
rbjtech 5344 Posted April 6, 2022 Posted April 6, 2022 This could be an Android 11 issue with the latest 'Nvidia Experience' - I'm still on Android 9 But this did previously work as I remember testing it on the original thread .. We probably need Eric to weigh in here to see if the App is recognising it as DTS-HR or just DTS ..
MrMackey 35 Posted April 6, 2022 Posted April 6, 2022 7 minutes ago, rbjtech said: This could be an Android 11 issue with the latest 'Nvidia Experience' - I'm still on Android 9 But this did previously work as I remember testing it on the original thread .. We probably need Eric to weigh in here to see if the App is recognising it as DTS-HR or just DTS .. Sure if you need more logs or test just let me know. I am currently on the latest hotfix 3 version.
ebr 16337 Posted April 6, 2022 Posted April 6, 2022 1 hour ago, rbjtech said: We probably need Eric to weigh in here to see if the App is recognising it as DTS-HR or just DTS 3 hours ago, ebr said: Hi. The player/device only sees it as DTS. Can you hear a difference?
MrMackey 35 Posted April 6, 2022 Posted April 6, 2022 4 hours ago, ebr said: Hi. The player/device only sees it as DTS. Can you hear a difference? I compared a few scenes where is a lot of action and music. Yes I find the sound is more detailed and has more dynamic. But that is just my opinion
