Zodler 18 Posted September 25, 2020 Author Posted September 25, 2020 Ok, I tested patch 3 with VPN ON. In-Home (LAN) access: 192.168.1.100:8096 And here is the log embyserver-63736646968.txt
mpcan 0 Posted November 3, 2020 Posted November 3, 2020 I am still on 4.4.3.0 and just had this problem. The In-Home LAN access randomly changed to a really crazy IP. It changed to 10.2.112.49:8096 whereas it should be (and has always been) 10.0.0.222:8096. I can't say why or how it changed, but then the Android (Shield 2019) client stopped working because it could not find the server. I am running Emby on a Synology DS418. I followed the guidance above regarding editing the IP address in the settings and this has resolved the issue.
Luke 42208 Posted November 3, 2020 Posted November 3, 2020 32 minutes ago, mpcan said: I am still on 4.4.3.0 and just had this problem. The In-Home LAN access randomly changed to a really crazy IP. It changed to 10.2.112.49:8096 whereas it should be (and has always been) 10.0.0.222:8096. I can't say why or how it changed, but then the Android (Shield 2019) client stopped working because it could not find the server. I am running Emby on a Synology DS418. I followed the guidance above regarding editing the IP address in the settings and this has resolved the issue. Hi there, I would suggest updating to 4.5.2 and then you might not have to customize the option anymore. 1
