Zodler 18 Posted September 23, 2020 Posted September 23, 2020 Since the update to 4.5.0.50, the server is getting crazy ip addresses like In-Home (LAN) access: 172.22.176.1 inside my network. So I can not use the server at all. Here is the log attached. A brand new clean server with no library at all. embyserver-63736493563.txt embyserver-63736493818.txt embyserver-63736494324.txt
Luke 42208 Posted September 23, 2020 Posted September 23, 2020 Hi, perhaps no lan connection was available at the time? It queries your system for network interfaces and gets their reported ip addresses. If you put ipconfig /all in a windows command prompt, does that ip address show up in there?
Zodler 18 Posted September 23, 2020 Author Posted September 23, 2020 My PC ip address is correct. It shows as IPv4 Address. . . . . . . . . . . : 192.168.1.100 That ip address that shows up in Emby Server is listed as Ethernet adapter vEthernet (Ethernet): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter Physical Address. . . . . . . . . : **-**-**-**-**-** DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : *********************(Preferred) IPv4 Address. . . . . . . . . . . : 172.22.176.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.240.0 Default Gateway . . . . . . . . . : DHCPv6 IAID . . . . . . . . . . . : *********** DHCPv6 Client DUID. . . . . . . . : **************************** DNS Servers . . . . . . . . . . . : *********** ************* NetBIOS over Tcpip. . . . . . . . : Enabled Why is it picking up Hyper-V Virtual Ethernet Adapter's address? I tried a clean server of a previous emby server and it correctly shows as 192.168.1.100. It's only this latest update.
Luke 42208 Posted September 23, 2020 Posted September 23, 2020 Windows thinks that is your preferred ethernet adapter. Can you change that in windows network settings? As far as comparison with previous version, yes it was being filtered out before, but that was causing the network address to not be detected for other users, so we had to correct that.
Zodler 18 Posted September 23, 2020 Author Posted September 23, 2020 IPv4 Address. . . . . . . . . . . : 192.168.1.100(Preferred) I have 3 set as preferred. I followed a guide to change network priority and set it at 3 while the other two are 5 but still doesn't take it. This getting too complicated for practical use. Can I add 192.168.1.100 manually in emby server?
Luke 42208 Posted September 23, 2020 Posted September 23, 2020 Yes you can in server network settings, but if you do that you have to be careful to keep that up to date if the machine ip changes Where does this virtual adapter come from? If I can simulate it then maybe we can do our own prioritization to prefer another instead. 1
Happy2Play 9802 Posted September 23, 2020 Posted September 23, 2020 (edited) The OS is giving that information to Emby. But I know my installation of Emby on host machine is not pulling my Hyper-V Virtual Ethernet Adapter (but testing I do see this using the Default Virtual Switch as it is using internal config). But if needed within your specific setup you can try to bind Emby to the correct network via Dashboard-Networks, Local IP address Local IP address: Optional. Override the local IP address that Emby Server will present to Emby apps. If left blank, the server will automatically detect the local IP address. Doing some more testing but I changed my virtual switch to external instead of interal and get proper lan ip. https://serverfault.com/questions/895739/ip-to-access-hyper-v-host-on-default-switch Edited September 23, 2020 by Happy2Play 1
Zodler 18 Posted September 23, 2020 Author Posted September 23, 2020 12 minutes ago, Luke said: Yes you can in server network settings, but if you do that you have to be careful to keep that up to date if the machine ip changes Where does this virtual adapter come from? If I can simulate it then maybe we can do our own prioritization to prefer another instead. It is windows virtual machine Hyper-V
Zodler 18 Posted September 23, 2020 Author Posted September 23, 2020 I just set it in Emby Netrwork settings and it works again. Did not go for External Virtual Switch.
Luke 42208 Posted September 23, 2020 Posted September 23, 2020 Ok here's a patched build of the stable release if you'd like to try this: https://www.dropbox.com/s/vhzs5w88m5ozi4h/embyserver-win-x64-4.5.0.50.7z?dl=0 It won't change anything but it will add extra logging for me. Just shutdown the server and unzip the system directory over the top. Then start it up and either attach the server log here or PM it to me. Thanks !
Luke 42208 Posted September 23, 2020 Posted September 23, 2020 You may need to temporarily undo the setting you configured or it may not query the network interfaces to produce the logging that i need. thanks.
Zodler 18 Posted September 23, 2020 Author Posted September 23, 2020 (edited) I always use it as a clean install for logging. Here is the log of the new patched version. embyserver-63736505541.txt Edited September 23, 2020 by Zodler
Luke 42208 Posted September 23, 2020 Posted September 23, 2020 So you were on wifi when you did this, is that correct?
Zodler 18 Posted September 23, 2020 Author Posted September 23, 2020 My internet is on wifi yes and the ip address is 192.168.1.100. I have no knowledge but shouldn't emby prioritize and take an internal ip like 192.168.1.*** first?
Happy2Play 9802 Posted September 23, 2020 Posted September 23, 2020 7 minutes ago, Zodler said: My internet is on wifi yes and the ip address is 192.168.1.100. I have no knowledge but shouldn't emby prioritize and take an internal ip like 192.168.1.*** first? With 192.168.0.0 – 192.168.255.255, 10.0.0.0 – 10.255.255.255 and 172.16.0.0 – 172.31.255.255 being private networks space, why? Sure most commercial routers will use 192.168.x.x ip space thought.
Luke 42208 Posted September 24, 2020 Posted September 24, 2020 Thank you for your help. Can you please try this version: https://www.dropbox.com/s/vhzs5w88m5ozi4h/embyserver-win-x64-4.5.0.50.7z?dl=0 Then let me know if it produces the desired result? Thanks.
Zodler 18 Posted September 24, 2020 Author Posted September 24, 2020 (edited) Yes, now it is working. I see some big errors in the log file. Is that ok? embyserver-63736548836.txt Edited September 24, 2020 by Zodler
Luke 42208 Posted September 24, 2020 Posted September 24, 2020 Ok one more time: https://www.dropbox.com/s/vhzs5w88m5ozi4h/embyserver-win-x64-4.5.0.50.7z?dl=0 This will add more new logging. thanks.
Zodler 18 Posted September 24, 2020 Author Posted September 24, 2020 Here: embyserver-63736572953.txt
Luke 42208 Posted September 24, 2020 Posted September 24, 2020 Well figures this time around those errors aren't there. Is the server dashboard still reporting your desired local address?
Zodler 18 Posted September 24, 2020 Author Posted September 24, 2020 Yes. It's 192.168.1.100. It's working I still see two blocks of errors in the log. It was just out of curiosity. By the way, I don't know why but since 2 days ago I'm unable to connect to your site and here. I have to use a VPN to be able to come here. If the server is contacting the site, that must be it.
Zodler 18 Posted September 24, 2020 Author Posted September 24, 2020 Ok, forget about the errors. I'm here now without VPN. I had to restart my ISP modem. Now as you see, there is no errors. Must have been a problem with my ISP. embyserver-63736584176.txt
Luke 42208 Posted September 24, 2020 Posted September 24, 2020 In both cases now with and without vpn, is the right local address detected?
Zodler 18 Posted September 25, 2020 Author Posted September 25, 2020 (edited) Yes as I said it is correct since patch 2 and It's set as 192.168.1.100. Patch 2 and patch 3 assign the correct local IP address. I tested it only with VPN off. Do you want me to test it with VPN on? Edited September 25, 2020 by Zodler
Luke 42208 Posted September 25, 2020 Posted September 25, 2020 If you could that would be great. I'd be curious to know the result. Thanks.
