Guest CodeCat5 Posted September 23, 2020 Posted September 23, 2020 (edited) *edit* Never mind, I fixed it. I noticed the in-home LAN address was showing up as 172.23.144.1, which is strange considering my local addresses are 10.x.x.x, and the host PC has always had a static IP since well before I installed Emby. Setting the correct address under Network -> Local IP address seems to have resolved it though. I just tried to load Emby and for some reason I suddenly can't connect. It just shows the Emby "Loading..." screen, then eventually kicks back to the screen where you can select the server and such. I select my server, but it says it's unavailable. I've tested on a Firestick, Nvidia Shield, and Samsung phone all on my local network and none of those work. However, I can connect through a web browser just fine through 2 different PC's (one of which is the host PC, the other is connected via wifi). When I first started troubleshooting I wasn't able to load Plex on any of my Android devices either, but something I did fixed Plex, just not Emby. I've tried restarting the Emby server, the Emby Host PC, and the Android client devices. I've also rebooted my router. As I mentioned I can access Emby from browsers on 2 different PCs and I can access Plex on my apps, so it doesn't seem to be anything to do with my network. Is there something else I can do to troubleshot? Edited September 23, 2020 by CodeCat5
Luke 42210 Posted September 24, 2020 Posted September 24, 2020 Hi, sounds like you've resolved it. Thanks for the feedback.
