buddyweiser 105 Posted January 6, 2015 Posted January 6, 2015 I can check it real quick Sent using my G3 1
buddyweiser 105 Posted January 6, 2015 Posted January 6, 2015 I've just deleted and re uploaded the Xenon.dll to the admin site. You need to be running version 243 of MBC and it should upgrade to Xenon 1.0.0.19 can anyone please test this thanks That does it bud, updated properly and now no message about an update pending. Sent using my G3 1
skynet600 33 Posted January 6, 2015 Posted January 6, 2015 I've just deleted and re uploaded the Xenon.dll to the admin site. You need to be running version 243 of MBC and it should upgrade to Xenon 1.0.0.19 can anyone please test this thanks Well I am on 1.0.0.19 now without a manual upgrade so I guess it works fine 1
Cheesegeezer 3106 Posted January 6, 2015 Author Posted January 6, 2015 Thanks peeps, I've also tested this with the new Dev Version of MBC which introduces the Web Client Folder structure, however legacy mode (i.e. the views we are used to) and the new views seem to be working fine as well. more info here http://mediabrowser.tv/community/index.php?/topic/16728-dev-build-245/ 1
Tester 45 Posted January 8, 2015 Posted January 8, 2015 Yep, update issue resolved, I am now running 1.0.0.19 The double click sound issue is still there but I am now used to it and is no big deal. The trailers still do not play but I believe this is a Cinema mode issue, so I will start a separate thread. My apologies for missing info & lack of logs: MBC 3.0.243.0 Server 3.0.5482.1 Thanks Cheese 1
ozijon 0 Posted February 1, 2015 Posted February 1, 2015 Hi i really like the Xenon theme but the problem is wmc control's cover over the Xenon control'sI can't use them Can this be fixedthank you
buddyweiser 105 Posted February 1, 2015 Posted February 1, 2015 Hi i really like the Xenon theme but the problem is wmc control's cover over the Xenon control's I can't use them Can this be fixed thank you Xenon is really designed for xbox 360 extenders...and while I use my pc as an MBC interface, I use a controller to navigate MBC. Perhaps you could tell us a little about your setup and I can help you. All I know from your post is that you use a mouse. Sent using my G3 1
Cheesegeezer 3106 Posted February 1, 2015 Author Posted February 1, 2015 Hi i really like the Xenon theme but the problem is wmc control's cover over the Xenon control's I can't use them Can this be fixed thank you Hi there, as @@buddyweiser said, it's not really designed for mouse use. If you have a keyboard, remote control or gamepad any of these can be used to control navigation around the UI. Unfortunately I wont be moving the Option Items, and unfortunately it is not possible to disable the WMC PLAY control panel either.
ozijon 0 Posted February 1, 2015 Posted February 1, 2015 Hi there, as @@buddyweiser said, it's not really designed for mouse use. If you have a keyboard, remote control or gamepad any of these can be used to control navigation around the UI. Unfortunately I wont be moving the Option Items, and unfortunately it is not possible to disable the WMC PLAY control panel either. ahh thank you my mini control works just fine never thought to use it before
ozijon 0 Posted February 1, 2015 Posted February 1, 2015 Xenon is really designed for xbox 360 extenders...and while I use my pc as an MBC interface, I use a controller to navigate MBC. Perhaps you could tell us a little about your setup and I can help you. All I know from your post is that you use a mouse. Sent using my G3 ahh thank you solved
jfblue65 2 Posted April 12, 2015 Posted April 12, 2015 G'day Guys Found this theme after a few issues with the movie/tv themes in Subdued. I know this is on Cheezegeezers list to look at. Had a look at this theme and like what I see. Undertand this is more designed for xBox Extender but I dont think this is related to me using it on my WMC. For my Movies, I have it set to view using Coverflow. When I push the right arrow key, it skips two movies at a time. If I try a different remote. Same result. Even on a keyboard. Same result. If I push the left arrow key, it goes back 1 movie. Doesnt matter what order I have the movies sorted. I typically have it sorted by "Unplayed". If I change the view option to Poster or Thumb, the right arrow skips 1 movie at a time as expected. The strange part is, my TV Shows are also set to coverflow but when I press the right arrow key, they skip 1 show at a time. as expected... Very confused...
Cheesegeezer 3106 Posted April 14, 2015 Author Posted April 14, 2015 G'day Guys Found this theme after a few issues with the movie/tv themes in Subdued. I know this is on Cheezegeezers list to look at. Had a look at this theme and like what I see. Undertand this is more designed for xBox Extender but I dont think this is related to me using it on my WMC. For my Movies, I have it set to view using Coverflow. When I push the right arrow key, it skips two movies at a time. If I try a different remote. Same result. Even on a keyboard. Same result. If I push the left arrow key, it goes back 1 movie. Doesnt matter what order I have the movies sorted. I typically have it sorted by "Unplayed". If I change the view option to Poster or Thumb, the right arrow skips 1 movie at a time as expected. The strange part is, my TV Shows are also set to coverflow but when I press the right arrow key, they skip 1 show at a time. as expected... Very confused... it's to do with your poster size, try decreasing them a little and this should solve your issues 1
jfblue65 2 Posted April 16, 2015 Posted April 16, 2015 Thanks Cheesegeezer. The more I decreased the size, the more movies that were skipped. I was skipping 4 at a time at one stage. That triggered me too go the other way and increase the size instead. I now have the poster size at a size that only skips 1 movie at a time.
