RonNCmale 3 Posted September 19, 2014 Posted September 19, 2014 Issue with blank RAL when returning to EHS is not fixed In View Options if EHS is only checked then when you click new and all new movies show, watched and unwatched, all work, But, If I click movies and then hit the back button and click on new, watched or unwatched it still shows "no items found". Note: But if I select both EHS and Show favorites folder then all works. I has something to do with the Show Favorites folder.
Cheesegeezer 3106 Posted September 19, 2014 Author Posted September 19, 2014 Issue with blank RAL when returning to EHS is not fixed In View Options if EHS is only checked then when you click new and all new movies show, watched and unwatched, all work, But, If I click movies and then hit the back button and click on new, watched or unwatched it still shows "no items found". Note: But if I select both EHS and Show favorites folder then all works. I has something to do with the Show Favorites folder. Ok mate, it's hard to fix something that i can't reproduce. 1st attempt = fail lol have you tried this with other themes..... namely chocolate as this is pretty much rock solid
RonNCmale 3 Posted September 19, 2014 Posted September 19, 2014 yes, I've tried it with chocolate and no issues. Have you tried to unchecked all in View Options except Enable EHS to reproduce this? I'm also stumped, but I do thank you for trying. Anything I can do to help, please do ask. Thanks 1
Cheesegeezer 3106 Posted September 20, 2014 Author Posted September 20, 2014 (edited) Having problems uploading this update - I will keep trying 1.0.0.10 - Big update - bug fixes and features Huge thanks to @@BAS for all his help with testing and improvements with this update Changelog -- General -- ++ Spinners Fixed - If at end jumps to other option - Context menu closes when selecting off for fanart type. ++ Actor Bio Page displays scroller for titles in your collection ++ Fix Watched indicator layout on Actor Bio Collection -- Details View -- ++ Add Poster option to spinner for fanart type in list view and position above overview. ++ Add option to set transparency of thumb. ++ Move Missing/Future Images to ThumbImage. -- Poster View -- ++ Make the poster scroller central to all for ease of navigation to config panel. -- EHS View -- ++ Added Backdrop Overlay and Opacity setting ++ NPV added to EHS - can't believe I missed that one Bugs still to fix Selecting EHS and Favorites Folder prevent user from using the RAL Selector Optios Entering an item and backing back out sometimes doesn't display RAL Backing out of a collection and navigating immediately on EHS forces scroller to the RAL and sometimes doesn't go back to EHS VF scroller Features to Add Shortlist Implementation - 95% Complete Create a Banner UI or Banner List for Details View - 0% Complete Hope you enjoy people. Edited September 21, 2014 by Cheesegeezer 3
Cheesegeezer 3106 Posted September 21, 2014 Author Posted September 21, 2014 1.0.0.10 is finally uploaded. Enjoy!! 1
Cheesegeezer 3106 Posted September 21, 2014 Author Posted September 21, 2014 Any takers willing to give the shortlist option a try out prior to release, need this testing. Cheers 1
Cheesegeezer 3106 Posted September 24, 2014 Author Posted September 24, 2014 IF YOU ENCOUNTER AN ERROR ON LOADING MBC PLEASE READ ON Unfortunately my IDE got all screwed up and I've had to build the latest version to MBC DEV version of 213. When I uploaded this I thought I had it set to minimum version of 213, however it set to the Release version of 207. This means that one of the assemblies versions is ahead of 207 and will fail to work with MBC version 207. This error has been fixed within our admin site and the version release info. To fix this, please uninstall and reinstall the Xenon Plugin and it should revert you back to 1.0.0.10. Once @@ebr releases the new beta/release, Xenon 1.0.0.11 will be available. 1.0.0.11 Changlog ------------------------- Removed some code that causes Chocolate Theme to break. (Evil Image that isn't resourced)
Cheesegeezer 3106 Posted September 24, 2014 Author Posted September 24, 2014 I'll be offline for a while again. Going back to the wilderness of non internet land and combine harvesters. Take care peeps 2
GShock 0 Posted October 12, 2014 Posted October 12, 2014 I cannot get the "Played Indicator" icons to show on anything. I have all the options checked but they're still not showing. Anyone have a solution for this?
Cheesegeezer 3106 Posted October 12, 2014 Author Posted October 12, 2014 I cannot get the "Played Indicator" icons to show on anything. I have all the options checked but they're still not showing. Anyone have a solution for this? Not sure if these options are server driven now, but ensure they are enabled there. Check chocolate theme to see if same behaviour occurs. Can you provide screenshots of you options checked in MBC. Just to be sure you are enabling correct options. Cheers
GShock 0 Posted October 12, 2014 Posted October 12, 2014 (edited) I can see the unplayed count icons. But I really want to get those check marks enabled to show what I've watched. I tried it in chocolate but I cannot see them there. Thanks for your help. Edit: I tried installing MBT and the played indicator icon works like it should. When I close MBT and open back MBC the played indicator (the check mark) is showing on the file which I played on MBT. But if I play a file through MBC the check mark won't show up after I finish watching the file. Is there anyway to apply the Xenon theme in MBT? Edited October 13, 2014 by GShock
Cheesegeezer 3106 Posted October 13, 2014 Author Posted October 13, 2014 I can see the unplayed count icons. But I really want to get those check marks enabled to show what I've watched. I tried it in chocolate but I cannot see them there. Thanks for your help. Edit: I tried installing MBT and the played indicator icon works like it should. When I close MBT and open back MBC the played indicator (the check mark) is showing on the file which I played on MBT. But if I play a file through MBC the check mark won't show up after I finish watching the file. Is there anyway to apply the Xenon theme in MBT? Ok I think I have an idea here.... your server has updated but you havent updated your MBC version. Current Beta is 2.21 for MBC IIRC. Give that a go and let me know. Also make sure that both Server update level (ie release, beta or dev) and MBC update levels are set the same. otherwise you may run into compatibility issues. Cheers
ebr 16343 Posted October 13, 2014 Posted October 13, 2014 It sounds to me like a problem with the items getting marked watched rather than the indicators.
Cheesegeezer 3106 Posted October 14, 2014 Author Posted October 14, 2014 huh, what's going on here I have 5 notifications for topic entries here but can only see ebr's comment after mine and they are all from last night. Anyway @@GShock have you managed to resolve this yet?
ebr 16343 Posted October 14, 2014 Posted October 14, 2014 His issue obviously had nothing to do with Xenon so I moved those items to a new topic.
Cheesegeezer 3106 Posted October 14, 2014 Author Posted October 14, 2014 His issue obviously had nothing to do with Xenon so I moved those items to a new topic. Probably the best thing to do. cheers
Cheesegeezer 3106 Posted October 17, 2014 Author Posted October 17, 2014 Server Beta Release 3.0.5400 breaks Xenon. It's to do with the new Security Authorization it now has implemented when making requests to the API. I am working on a fix and will update with a new release in the next couple of days. Apologies for any inconvenience. 1
Cheesegeezer 3106 Posted October 21, 2014 Author Posted October 21, 2014 Beta Version 1.0.0.12 is up. This implements the new API Authorization requirements for server build 5400 If you are using 5.0.5400 Server or above please report back any issues, mainly with Upcoming TV, Next Up and Actor Bios Thanks
Cheesegeezer 3106 Posted October 28, 2014 Author Posted October 28, 2014 Minor Update just gone up 1.0.0.14 - Imdb & Tomatos Ratings Upgrade ----------------------------------------------------------- This update bring the options for each Folder level to choose the style of rating system you wish to be displayed. Options are Off - No rating system Star Graph - Shows the Stars Numeric - Shows Imdb rating in a numeric value in imdb icon. Rotten Tomato - Shows Rotton Tomatoes rating and icon Numeric/Tomato - Shows both Imdb and Rotton Tomato Ratings and icon To Edit the Colors and Fonts for the new feature please read on. Color for IMDB numeric shares the same color as Star Graph and can be found here to change in the styles mcml file. <Color Name="StarsColor" Color="255,255,30" /> All Numeric Numbers are taken from the Counter Font and Color <Font Name="counterFont" Font="InterBold, 14" /> <Color Name="counterColor" Color="210,210,210" /> Example of Numeric/Tomato Option Selected for Movies
Cheesegeezer 3106 Posted October 28, 2014 Author Posted October 28, 2014 1.0.0.15 - NEW FEATURE TO MBC - SHORTLIST ---------------------------------------------------------------- The New Shortlist feature, only available in Xenon allows you to pick and chose content via the Context Menu (Asterix * Key) and Add or Remove Items from your newly created shortlist. It means that you can select Movies throughout any of your collections and add them to a seperate list, for those times when it's difficult to decide what move to watch. This is the initial release and there is a lot more to come from this feature, however at the moment there is great functionality. Here's some Screenies to wet the appetite!! Enjoy Pressing * on your remote or keyboard brings up the context menu and now allows you to add/remove items from the Shortlist Once you have chosen some movies, you need to click on the Shortlist Icon in the Config Panel at the Top Right Corner View your Shortlist and if you wish to remove items from it, simply press the * Key and select Remove from Shortlist Option There are options to Close or Clear your Shortlist. The Shortlist Resets itself if you exit MBC.
Cheesegeezer 3106 Posted November 3, 2014 Author Posted November 3, 2014 1.0.0.17 ---------- ++ Added option to turn off MBNews Scroller ++ Fixed image overlay on Details page again for missing future and remote content. ++ Removed the RAL scroller moving to First Item on EHS, causing weird nav issues at the moment. ++ Fixed Details Thumb image not rotating backdrop when no thumb is available & added logo to the backdrop image now. ++ Add in MB Event Info Panel on all views (Such as "Welcome to MediaBrowser" - "MB-Classic is up to date" - "Refresh [itemName]" 1
Cheesegeezer 3106 Posted November 3, 2014 Author Posted November 3, 2014 (edited) @@buddyweiser @@yardameus @@aspdend @@Echostorm How are you guys finding the Shortlist feature. i've not heard anything so assuming it's working well for you.... It's not the final interface I want for the user, but it's a start. Edited November 3, 2014 by Cheesegeezer 1
yardameus 221 Posted November 3, 2014 Posted November 3, 2014 Yeah, I just checked it out last night. Worked like a charm. Easily added several movies, cleared out with no problem. 1
