Echostorm 7 Posted August 23, 2014 Posted August 23, 2014 Thanks for the heads up bud, you're leaving it in really great shape. 2
Echostorm 7 Posted September 10, 2014 Posted September 10, 2014 Hope all is going well for you bud. The theme is perfect but I can't seem to find any documentation on how to setup that brushed steel background in the EHS and config screens I see in your screenshots. Thanks again!
Cheesegeezer 3106 Posted September 10, 2014 Author Posted September 10, 2014 (edited) Hope all is going well for you bud. The theme is perfect but I can't seem to find any documentation on how to setup that brushed steel background in the EHS and config screens I see in your screenshots. Thanks again! EDIT: thanks but I wouldn't say it's perfect. lots of little things to tidy up!! It's an MCS (MediaCenter Studio) theme I modified. https://www.dropbox.com/s/8zul81wri5hj3qt/Concrete.mct?dl=0 I could add a theme Backdrop of it which you can select from the main config under Theme Options and Show Theme Background. Edited September 10, 2014 by Cheesegeezer
Echostorm 7 Posted September 11, 2014 Posted September 11, 2014 That's awesome bud, thanks very much.
Cheesegeezer 3106 Posted September 11, 2014 Author Posted September 11, 2014 That's awesome bud, thanks very much. awesome for the mct file or if I add a theme background?
Redshirt 1487 Posted September 11, 2014 Posted September 11, 2014 Cheese. Loving the theme... but this one thing is driving me nuts. It's like Gorbachev's forehead, you can't not look at it 1
Cheesegeezer 3106 Posted September 11, 2014 Author Posted September 11, 2014 Cheese. Loving the theme... but this one thing is driving me nuts. It's like Gorbachev's forehead, you can't not look at it Hahahahah yeah it is a bit. Great catch Red and thanks, glad you like it. Damn i thought i put in the logic to remove that if the RAL was turned off..... finally an easy fix to do!!! 1
RonNCmale 3 Posted September 11, 2014 Posted September 11, 2014 (edited) RonNCmale quote: I'm not sure if this is a bug or if it is the way xenon is suppose to work. I can open media browser and click new and all new movies show, watched and unwatched, all work, But, If I click movies and then hit the back button and click on new, watched or unwatched it shows "no items found". Is this normal for xenon. Cheezegeezer quote: Nope, it must not be refreshing the list when returning to the ehs. I'll look into it for you. Have ya had a chance to look into it yet? Thanks Also how do you add a theme (Concrete.mct file) to xenon Edited September 11, 2014 by RonNCmale
Cheesegeezer 3106 Posted September 12, 2014 Author Posted September 12, 2014 (edited) RonNCmale quote: I'm not sure if this is a bug or if it is the way xenon is suppose to work. I can open media browser and click new and all new movies show, watched and unwatched, all work, But, If I click movies and then hit the back button and click on new, watched or unwatched it shows "no items found". Is this normal for xenon. Cheezegeezer quote: Nope, it must not be refreshing the list when returning to the ehs. I'll look into it for you. Have ya had a chance to look into it yet? Thanks Also how do you add a theme (Concrete.mct file) to xenon Unfortunately, I had completely forgotten about it, with the move and all. I'll add it to my list now. @@buddyweiser @@yardameus @@aspdend can you repo this issue above? Thanks I have been trying to repo this issue and can't. What versions are you running for MBC and MBS please. So as there have been a couple of requests, I've added the "Concrete" background to the theme as the theme background, however if you can't wait for next update here's how you can add it. You need a program called MediaCenter Studio Follow these instructions here on how to install http://www.hack7mc.com/2011/11/media-center-studio-installation.html To install the theme: For those unfamiliar with Media Center Studio simply run the program and select the Themes tab. From that tab select the Import Theme button and select the Concrete MCT file to add it to Media Center Studio’s theme listing. From there select the New theme and press the Apply button. The theme will be applied to Media Center and should appear the next time you launch the program. Edited September 12, 2014 by Cheesegeezer
RonNCmale 3 Posted September 12, 2014 Posted September 12, 2014 I'm using the following MBS=Version 3.0.5366.22005 MBC=3.0.207.0
buddyweiser 105 Posted September 12, 2014 Posted September 12, 2014 Unfortunately, I had completely forgotten about it, with the move and all. I'll add it to my list now. @@buddyweiser @@yardameus @@aspdend can you repo this issue above? Thanks I have been trying to repo this issue and can't. What versions are you running for MBC and MBS please. I can reproduce the issue Cheese. However, for me it only happens on TV shows, not Movies, or Games or any other category I tested.
RonNCmale 3 Posted September 12, 2014 Posted September 12, 2014 I found the bug, In View Options if you enable only EHS then I can open media browser and click new and all new movies show, watched and unwatched, all work, But, If I click movies and then hit the back button and click on new, watched or unwatched it shows "no items found". Is this normal for xenon. But if I select both EHS and Show favorites folder then I can go back and forth. I has something to do with the Show Favorites folder. I only enable EHS. hope this helps.
Cheesegeezer 3106 Posted September 12, 2014 Author Posted September 12, 2014 I has something to do with the Show Favorites folder. I only enable EHS. Can you explain more. What are you actually doing to repo the issue?
Echostorm 7 Posted September 12, 2014 Posted September 12, 2014 awesome for the mct file or if I add a theme background? Both.
Cheesegeezer 3106 Posted September 12, 2014 Author Posted September 12, 2014 Both. I've add the "Concrete" Background to the theme which will be in the next release. 2
Yogi 367 Posted September 12, 2014 Posted September 12, 2014 Hey Cheese, I haven't been around much lately,but I sat down to watch a movie tonight and noticed that the video backgrounds are playing but cannot be viewed, This is happening in both Xenon and Subdued,all other themes are working fine. MBC .211
Cheesegeezer 3106 Posted September 12, 2014 Author Posted September 12, 2014 Hey Cheese, I haven't been around much lately,but I sat down to watch a movie tonight and noticed that the video backgrounds are playing but cannot be viewed, This is happening in both Xenon and Subdued,all other themes are working fine. MBC .211 That's a dev version. I haven't tested Xenon with any later releases than 207. Or Subdued for that matter. When you say playing but cannot be viewed, do you mean they are playing in the background but when you click on now playing icon, it doesn't go to full screen. Which other themes are working fine? Cheers bud
Yogi 367 Posted September 12, 2014 Posted September 12, 2014 That's a dev version. I haven't tested Xenon with any later releases than 207. Or Subdued for that matter. When you say playing but cannot be viewed, do you mean they are playing in the background but when you click on now playing icon, it doesn't go to full screen. Which other themes are working fine? Cheers bud Yes they are playing in the background and there is no now playing icon showing to click on. Chocolate,Square,Rush,Roc,Crystal even the good old ones Pearl,Neo and Diamond working correctly.
Yogi 367 Posted September 12, 2014 Posted September 12, 2014 (edited) Did some troubleshooting and unfortunately it didn't enlighten anything, Reverted back to latest official release of MBC .207 and uninstalled both Xenon and Subdued,then removed all references and folders belonging to both.and reinstalled both from MBC but still the same problem. If you cannot figure it out,it doesn't matter that much as I have not got the time to do to much troubleshooting or watch anything at the moment. Edited September 12, 2014 by Yogi
RonNCmale 3 Posted September 12, 2014 Posted September 12, 2014 RonNCmale, on 12 Sept 2014 - 05:35 AM, said: I has something to do with the Show Favorites folder. I only enable EHS. Can you explain more. What are you actually doing to repo the issue? Open MBC and select View Options under Top Level Views; Uncheck all boxes except EHS. Select continue and then exit MBC. Restart MBC and this should repo the issue. Now If you click movies and then hit the back button and click on new, watched or unwatched it shows "no items found".
Cheesegeezer 3106 Posted September 12, 2014 Author Posted September 12, 2014 RonNCmale, on 12 Sept 2014 - 05:35 AM, said: Can you explain more. What are you actually doing to repo the issue? Open MBC and select View Options under Top Level Views; Uncheck all boxes except EHS. Select continue and then exit MBC. Restart MBC and this should repo the issue. Now If you click movies and then hit the back button and click on new, watched or unwatched it shows "no items found". So Where is movies in your Sort Order for the EHS is it the first in the list. How big is you list, have you been patient enough, give it a few seconds and see what happens. it repopulates the quick lists when returning home page. Ok, so I've tried everything to repo this and can't repo it at all. I have a small library on my dev laptop which has approx 20 - 30 movies in. So this could be it.
ebr 16342 Posted September 12, 2014 Posted September 12, 2014 Cheese - why are you manually updating those lists? They will refresh automatically whenever anything in the library changes.
Cheesegeezer 3106 Posted September 12, 2014 Author Posted September 12, 2014 Cheese - why are you manually updating those lists? They will refresh automatically whenever anything in the library changes. I'm not, maybe I didn't explain myself very well in the answer above.
RonNCmale 3 Posted September 12, 2014 Posted September 12, 2014 (edited) RonNCmale, on 12 Sept 2014 - 11:05 AM, said: RonNCmale, on 12 Sept 2014 - 05:35 AM, said: Can you explain more. What are you actually doing to repo the issue? Open MBC and select View Options under Top Level Views; Uncheck all boxes except EHS. Select continue and then exit MBC. Restart MBC and this should repo the issue. Now If you click movies and then hit the back button and click on new, watched or unwatched it shows "no items found". So Where is movies in your Sort Order for the EHS is it the first in the list. (No, it second- right after Favorites if both EHS and Favorites list is checked, Normally it is the only one that shows if EHS is the only one checked----- see post #48 on this topic, it shows how it normally looks with just Movies showing) How big is you list, have you been patient enough, give it a few seconds and see what happens. it repopulates the quick lists when returning home page. (50 movies, I've let it sit for more than 10 minutes and it does not repo) Ok, so I've tried everything to repo this and can't repo it at all. I have a small library on my dev laptop which has approx 20 - 30 movies in. So this could be it. Edited September 12, 2014 by RonNCmale
