ryanfinger 6 Posted September 22, 2020 Posted September 22, 2020 Just upgraded to the latest emby server version. Since then I'm experiencing audio sync issues on live TV. It doesn't happen right away when tuning a channel but usually 5-30 mins later. Stopping the live TV stream and restarting resets the clock but the issue returns.
jachin99 88 Posted September 23, 2020 Posted September 23, 2020 I had the same issue in Emby on a few different clients, and I had the same problem on the Live Channels Android TV app. I updated my graphics card driver, tuner firmware, and HD Homerun setup app. I'm not sure what tuner your using but I have the HD Homerun Prime. I'm still testing to see if I get an issue but so far I haven't seen the issue pop back up. 1
Carlo 4561 Posted September 24, 2020 Posted September 24, 2020 If you see this issue in Live Channels that seems to indicate it's not an Emby issue. Check the firmware on the HDHomeRun to see if there is a new version.
jachin99 88 Posted September 24, 2020 Posted September 24, 2020 I don't trust it enough yet but i have noticed a big improvement since I made my changes. I have only had one mishap since and it was on the xb1 client, which crashes often all on its own
