b0ushard 0 Posted September 22, 2020 Posted September 22, 2020 Hi, encounter some playback problem with my new TV and Emby app 1.0.83 With a couple of movie the sound cut for moment and came back. This occur on "old" mkv files I have. Can someone have any Idea about this issue!?! Happen on Back to the Future I with DTS 5.1 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1 h 56 min Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 638 MiB (5%) Language : French And Kill Bill I also with DTS 5.1 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1 h 50 min Bit rate mode : Constant Bit rate : 755 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Delay relative to video : 11 ms Stream size : 598 MiB (7%) Title : FR DTS Language : French
Luke 42242 Posted September 22, 2020 Posted September 22, 2020 HI there, can you please attach the emby server and ffmpeg log (if there was one)? Thanks.
b0ushard 0 Posted September 22, 2020 Author Posted September 22, 2020 16 minutes ago, Luke said: HI there, can you please attach the emby server and ffmpeg log (if there was one)? Thanks. ffmpeg-remux-cfdbd07c-9371-4edd-85e8-3e39978c0d81_1.txtembyserver.txt Here they are!!
SamES 1084 Posted September 22, 2020 Posted September 22, 2020 As DTS is no longer supported by Samsung (since 2018) you are stuck with the server converting the audio which can start to add small issues and possible delays due to cpu and network loads. Ideally you should try and select an alternative supported track type, or if possible add a compatible track to the original file so that it DirectPlays. There are also a lot of these error messages in the remux log, so there may be some timing issues with the file which could be causing the audio dropouts 22:26:41.104 [segment @ 0000028569d28040] Non-monotonous DTS in output stream 0:1; previous: 13458480, current: 13457760; changing to 13458481. This may result in incorrect timestamps in the output file. 22:26:41.155 [segment @ 0000028569d28040] Non-monotonous DTS in output stream 0:1; previous: 13733970, current: 13732350; changing to 13733971. This may result in incorrect timestamps in the output file.
b0ushard 0 Posted September 22, 2020 Author Posted September 22, 2020 do you know where I can find the audio compatibility list !?! If not I'll try reloading some of my movies!!
FrostByte 5453 Posted September 23, 2020 Posted September 23, 2020 Here is a link to the developers page https://developer.samsung.com/smarttv/develop/specifications/media-specifications/2020-tv-video-specifications.html It should also be in a chart inside your users manual, probably toward the end. Looking at the chart anything that isn't specified will need to be converted by either yourself, or the server during playback. A lot of movies have both a HD and a compatible audio track (usually AC3), then before clicking play you just select the compatible track so it Direct Plays 1
Luke 42242 Posted September 29, 2020 Posted September 29, 2020 Have you updated to Emby Server 4.5? Has that helped? (Not expecting it to but just curious) thanks.
b0ushard 0 Posted September 29, 2020 Author Posted September 29, 2020 3 hours ago, Luke said: Have you updated to Emby Server 4.5? Has that helped? (Not expecting it to but just curious) thanks. The server is up to date! 4.5.0.50 Tried another version of the same movie and the sync seems to stay in place! I'll try to find other version of the "defective" movies!
