Eddie 12 Posted September 22, 2020 Posted September 22, 2020 (edited) I am running emby version 4.4.3.0 I am running emby inside if docker using image image: linuxserver/emby from here https://fleet.linuxserver.io/image?name=linuxserver/emby I am trying to make emby save Movies and TV shows captured from my HDHomeRun PRIME (Model: HDHR3-CC) to separate folders. Right now its saving perfectly fine using the following settings but its saving both movies and TV shows into the "Recordings" folder ++++++++++++++++++++++++++++++++++++++++++++++ Default recording path: /media/user/smbshare/Recordings Specify the default location to save recordings. If left empty, the server's program data folder will be used. Movie recording path (optional): Series recording path (optional): +++++++++++++++++++++++++++++++++++++++++++++++++ I changed the settings to this +++++++++++++++++++++++++++++++++++++++++++++++++ Default recording path: /media/user/smbshare/Recordings Specify the default location to save recordings. If left empty, the server's program data folder will be used. Movie recording path (optional): /media/user/smbshare/Recordings/Movies Series recording path (optional): /media/user/smbshare/Recordings/TV ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ and now it created 3 Folders in the library instead of 2 I now have 1 x Recorded Movies 2 x Recorded Shows instead of 1 x Recorded Movies 1 x Recorded Shows Why do i have 2 x Recorded Shows instead of one changed my settings back to normal and the 3 extra folders got removed automatically 1 x Recorded Movies 2 x Recorded Shows Edited September 22, 2020 by Eddie
mickle026 653 Posted September 25, 2020 Posted September 25, 2020 (edited) Not a new bug. Its been around for ages. You have to let the library scan complete successfully before adding or deleteing any libraries, if not you'll get multiple libraries. When you set up the DVR libraries, set up ONE at a time and click only ONCE!!! If no response do not click again, close the browser, reopen and WAIT for the library scan to COMPLETE. It might take a while to even start. Set up the scond path and allow it to scan again and complete again. For each path you create it can create 3 libraries. The Main, The New TVSHows and The new TV Movies paths, There a 3 seperate threads running in the background, ALL OF THEM trying to create the libraries, thats why you can get 3 for each !!! Sometimes a total of up to 9.... There should be a test to see if it exists, and skip it in the seperate threads, but there doesn't appear to be. If it has still created multiples then remove the others and ALLOW the scan to complete FULLY. It will fix itself then. It just takes a while.@Luke Tagged you Luke just in case you were not aware that every build up to 4.6.0.1 beta still does this Edited September 27, 2020 by mickle026 Tagged Luke 1 1
Eddie 12 Posted September 27, 2020 Author Posted September 27, 2020 Thank you for your response, should i delete my default recording path and leave it blank if i am going to specify location for TV and movies?
mickle026 653 Posted September 28, 2020 Posted September 28, 2020 I am not sure if it affects anything, but my default recording path is blank. Blank will default to Emby original setup path.
