troyhough 61 Posted September 23, 2020 Author Posted September 23, 2020 On 9/21/2020 at 1:30 PM, troyhough said: Got a notification for a server upgrade this morning so I ran it. I tried the "restart" function via both the Chrome Android web version (4.4.3.48) and the Android app (3.1.38) and neither worked on 4.5.0.50. If I right-click Emby in the system tray from the server itself and choose 'restart' it works as it's supposed to. I just tried the restart option in the Emby Android app (4.4.3.49) and Android Web Mobile (3.1.39). Both seem to be working fine again. Thanks
homelabsol 0 Posted September 23, 2020 Posted September 23, 2020 (edited) Firewall is off. No issue with the firewall. I tested it again this morning and even from internal i can't access it. See attached. I tried accessing it via ip address and port 8906 and 8920, however, both is not working. As i mentioned, i have experienced this on this update ONLY. Edited September 23, 2020 by homelabsol Will add screenshot
Happy2Play 9802 Posted September 23, 2020 Posted September 23, 2020 1 hour ago, homelabsol said: Firewall is off. No issue with the firewall. I tested it again this morning and even from internal i can't access it. See attached. I tried accessing it via ip address and port 8906 and 8920, however, both is not working. As i mentioned, i have experienced this on this update ONLY. That first error would suggest the system does not support HTTP2. https://emby.media/community/index.php?/topic/90114-ssl-issue-in-chromefirefox-after-upgrade-to-latest/ But the url in first image will not be accessible or refreshable as no dlgxxxxxxxxxxxxx pop-ups are.
homelabsol 0 Posted September 24, 2020 Posted September 24, 2020 @Luke I can't access this link anymore. Can you help me get this? https://www.dropbox.com/s/vhzs5w88m5ozi4h/embyserver-win-x64-4.5.0.50.7z?dl=0
homelabsol 0 Posted September 24, 2020 Posted September 24, 2020 Thank you very much Happy2Play for pointing me to the problem im experiencing right now.
Happy2Play 9802 Posted September 24, 2020 Posted September 24, 2020 5 minutes ago, homelabsol said: @Luke I can't access this link anymore. Can you help me get this? https://www.dropbox.com/s/vhzs5w88m5ozi4h/embyserver-win-x64-4.5.0.50.7z?dl=0 The link opens fine for me
homelabsol 0 Posted September 24, 2020 Posted September 24, 2020 Thanks Happy2. I'll try it again later. For now i just restored my previous snapshot. Later i will try to update again or will move my emby to 2016 server instead.
homelabsol 0 Posted September 26, 2020 Posted September 26, 2020 I have another concern, it seems your new version is not good for network mapping. The path of my movie files can't reach the network when trying to add new folder from the library. I'm always getting path could not be found which it doesn't happen on my previous server. Im currently upgraded to server 2016. I tried again the network path of my movies from my old emby on server 2012 r2 and it seems i don't have any issue on it. Also, i tried to do a manual backup from 2012 r2 to 2016, it copied everything, but when im playing the movies, due to the network path problem, i always get this error. Any solution? Please bear in mind, i don't have firewall, my network setup is normal. I tried to do the network path on server 2016 itself and i don't have any problem mapping the location. I only experienced the network mapping problem from emby.
Carlo 4561 Posted September 26, 2020 Posted September 26, 2020 What user on the OS are you running Emby as?
Luke 42210 Posted September 26, 2020 Posted September 26, 2020 13 hours ago, homelabsol said: I have another concern, it seems your new version is not good for network mapping. The path of my movie files can't reach the network when trying to add new folder from the library. I'm always getting path could not be found which it doesn't happen on my previous server. Im currently upgraded to server 2016. I tried again the network path of my movies from my old emby on server 2012 r2 and it seems i don't have any issue on it. Also, i tried to do a manual backup from 2012 r2 to 2016, it copied everything, but when im playing the movies, due to the network path problem, i always get this error. Any solution? Please bear in mind, i don't have firewall, my network setup is normal. I tried to do the network path on server 2016 itself and i don't have any problem mapping the location. I only experienced the network mapping problem from emby. Hi, let's look at an example. Please see how to report a media playback issue. thanks !
