Dariusz 25 Posted September 21, 2020 Posted September 21, 2020 so i recently got a sony TV (x900h) which has a built in android TV. i installed the latest emby app on it and i noticed when playing back 4K content, or any content for that matter, the display mode in the video settings always shows (1080/60.00) with no way of selecting any other resolution. when I display stats for nerds, it says it is direct playing at 4k. just wondering if this is an emby issue, or android TV issue? I also have a firestick 4k with emby installed, and there if I play 4k content i get 2160/23.98 in the display mode when playing back same video (also gives options for other resolutions). i have attached 2 log files.. (2) one is while playing back on android TV and (3) is playing back using firestick.. files were played today sept 21st between 10:20am-10:30am EDT. they both seem to be direct playing, so not sure if there is any useful info there.. but i do wonder why the emby on android TV only has 1080/60.00 for the display mode. embyserver (2).txt embyserver (3).txt
ebr 16338 Posted September 21, 2020 Posted September 21, 2020 Hi. There are a couple of threads on this out here but the TVs run their UI at 1080 and that is what they report as the mode even when video is actually being rendered in 4K. In short, everything is fine and it is just an erroneous display number in this case.
Dariusz 25 Posted September 21, 2020 Author Posted September 21, 2020 51 minutes ago, ebr said: Hi. There are a couple of threads on this out here but the TVs run their UI at 1080 and that is what they report as the mode even when video is actually being rendered in 4K. In short, everything is fine and it is just an erroneous display number in this case. that's great to hear. thank you so much for this info!
