NorthDegree 10 Posted September 21, 2020 Posted September 21, 2020 I am referring to the Nvidia Shield home screen specifically. I have both Emby Channels selected but for some reason after I use emby and go back to the shield home screen my "next up" list items are all duplicated. The only fix is go go back into emby and quit then reopen the app.
ebr 16338 Posted September 21, 2020 Posted September 21, 2020 Hi. Can you identify the exact situation that causes this? I've seen it before but not been able to duplicate to know what causes it. Thanks.
NorthDegree 10 Posted September 22, 2020 Author Posted September 22, 2020 thanks for the reply, it happened every time I watched a TV show but yesterday it did not occur on my shield #1 and only on shield #2. I will test it out again today
13rennon 2 Posted March 1, 2021 Posted March 1, 2021 (edited) Bit of a necro, but I also have this issue. Only happens if I don't finish a show, any show that is partially viewed and would default to resuming does this. Edit: Clarification -- Partially viewing any show causes ALL shows in Next Up to duplicate, not just the partially viewed show. Edited March 1, 2021 by 13rennon
Luke 42246 Posted March 2, 2021 Posted March 2, 2021 5 hours ago, 13rennon said: Bit of a necro, but I also have this issue. Only happens if I don't finish a show, any show that is partially viewed and would default to resuming does this. Edit: Clarification -- Partially viewing any show causes ALL shows in Next Up to duplicate, not just the partially viewed show. Hi there, can you please go over an example? Thanks.
ebr 16338 Posted March 2, 2021 Posted March 2, 2021 5 hours ago, 13rennon said: Partially viewing any show causes ALL shows in Next Up to duplicate Okay, that's interesting information... However, this functionality is going to be changing with the next server release so we may want to just re-evaluate then.
