ricky_buyo 4 Posted September 20, 2020 Posted September 20, 2020 Good morning I am having an issue with the usb installation. I insert the usb into the TV, but it doesn't automatically install the software. I have followed all the instrutions: - put the userwidget folder in the root of the usb - format the usb 2.0 to fat16 My TV is Samsung UE50RU7105 Any advice? (I can also post in Spanish)
FrostByte 5453 Posted September 20, 2020 Posted September 20, 2020 Also, if you had a previous version installed it will not install. Most people have to uninstall then reinstall from usb. Usually if there is just the one pop up in the upper right corner it could not find the install files, or you had a previous version installed and it couldn't start the install
ricky_buyo 4 Posted September 22, 2020 Author Posted September 22, 2020 Nothing happens. It detects the usb, allows me to see the folder inside... but the installation doesn’t start. No, there is no previous version of emby
Luke 42239 Posted September 22, 2020 Posted September 22, 2020 Where are you located? Are you able to install from the store?
mgworek 134 Posted September 22, 2020 Posted September 22, 2020 On 9/20/2020 at 2:28 AM, ricky_buyo said: Good morning I am having an issue with the usb installation. I insert the usb into the TV, but it doesn't automatically install the software. I have followed all the instrutions: - put the userwidget folder in the root of the usb - format the usb 2.0 to fat16 My TV is Samsung UE50RU7105 Any advice? (I can also post in Spanish) The last time I tried, within the last month, I had issues as well. I uninstalled, unplugged tv. I got it working but taking the contents in the userwidget folder and copying them to the root. Then it installed. Copying the folder to root didn't do anything for me.
ricky_buyo 4 Posted September 22, 2020 Author Posted September 22, 2020 56 minutes ago, Luke said: Where are you located? Are you able to install from the store? I am in Spain, so I think I can't install Emby from the store
ricky_buyo 4 Posted September 22, 2020 Author Posted September 22, 2020 8 minutes ago, mgworek said: The last time I tried, within the last month, I had issues as well. I uninstalled, unplugged tv. I got it working but taking the contents in the userwidget folder and copying them to the root. Then it installed. Copying the folder to root didn't do anything for me. Do you mean unzipping the 2 files from the userwidget folder directly into the root? I tried, but nothing happens.
mgworek 134 Posted September 22, 2020 Posted September 22, 2020 4 minutes ago, ricky_buyo said: Do you mean unzipping the 2 files from the userwidget folder directly into the root? I tried, but nothing happens. yea. That's what worked for me. I will double check my usb stick when I get home, it's still in the tv.
Luke 42239 Posted September 22, 2020 Posted September 22, 2020 Well that's interesting. If that's true then we might have different install methods based on different models. @FrostByte @SamES
FrostByte 5453 Posted September 22, 2020 Posted September 22, 2020 (edited) 3 hours ago, ricky_buyo said: Nothing happens. It detects the usb, allows me to see the folder inside... but the installation doesn’t start. No, there is no previous version of emby Even if you didn't have Emby install files on the usb you should at least get the first pop up in the upper right corner asking if you want to browse the usb disc. Hopefully you are getting that. Is the only thing on your usb the userwidget folder and the 2 files inside the folder? \userwidget \userwidget\emby.tmg \userwidget\widget.license Edited September 22, 2020 by FrostByte
FrostByte 5453 Posted September 22, 2020 Posted September 22, 2020 1 hour ago, Luke said: Well that's interesting. If that's true then we might have different install methods based on different models. @FrostByte @SamES I just tried it without the userwidget folder and all it did was display the pop up asking if I wanted to browse the usb disc. Without the userwidget folder it doesn't start the install. @mgworek what model TV do you have?
FrostByte 5453 Posted September 22, 2020 Posted September 22, 2020 @ricky_buyo are you using a usb drive? I've tried my western digital passport and it doesn't work for me. I had to use a thumb drive or stick Also, how big is your thumb drive? Another thing, does your usb have a write protect on it? If it does make sure you can write to the usb because the install process will need to write.
ricky_buyo 4 Posted September 22, 2020 Author Posted September 22, 2020 1 hour ago, FrostByte said: @ricky_buyo are you using a usb drive? I've tried my western digital passport and it doesn't work for me. I had to use a thumb drive or stick Also, how big is your thumb drive? Another thing, does your usb have a write protect on it? If it does make sure you can write to the usb because the install process will need to write. Yes, I do get the message to browse the usb, but the installation does not start. I am going to try the “universal solution” and restart to factory settings. I’ll let you know. 1
ricky_buyo 4 Posted September 23, 2020 Author Posted September 23, 2020 FIXED As I said, I have restored to factory settings and started the process all over again. Don't ask me why, but it worked. Thanks everybody for your help & time 2
FrostByte 5453 Posted September 23, 2020 Posted September 23, 2020 1 hour ago, ricky_buyo said: FIXED As I said, I have restored to factory settings and started the process all over again. Don't ask me why, but it worked. Thanks everybody for your help & time Great, thanks for reporting back. I'm sure this will help someone else in the future
springbok0 1 Posted October 4, 2020 Posted October 4, 2020 I'm having the exact same problem with installation on a Samsung Smart TV. Tried multiple USB sticks. I guess I should try the factory reset method and try again. I'm a bit puzzled as to why the app isn't in the Samsung store for all regions? I was quite disappointed to find this after subscribing.
Luke 42239 Posted October 4, 2020 Posted October 4, 2020 1 hour ago, springbok0 said: I'm having the exact same problem with installation on a Samsung Smart TV. Tried multiple USB sticks. I guess I should try the factory reset method and try again. I'm a bit puzzled as to why the app isn't in the Samsung store for all regions? I was quite disappointed to find this after subscribing. Hi, unfortunately Samsung makes its pretty hard to release worldwide. More info can be found here: Thanks.
springbok0 1 Posted October 9, 2020 Posted October 9, 2020 On 04/10/2020 at 17:01, Luke said: Hi, unfortunately Samsung makes its pretty hard to release worldwide. More info can be found here: Thanks. Thanks Luke. Would have thought Samsung would have made the process a bit slicker than that. Resetting the TV and inserting the USB seems to have worked though. 1
psxlover 32 Posted November 8, 2020 Posted November 8, 2020 Perhaps you had installed the application already, but you had no shortcut installed. So when you tried installing a new version it didn't work (as Frostbyte said you need to uninstall older versions otherwise the installation wont start) Next time try going into Apps -> Settings and see if it appears there. 1
FrostByte 5453 Posted November 8, 2020 Posted November 8, 2020 Some people in the past have deleted the Home shortcut and thought it's also deleting the app, but it doesn't
CogyG 3 Posted December 10, 2020 Posted December 10, 2020 I have the same problem. - USB is 3,4 gb - Tizen.rar file on the usb - Unpack with the maps on the usb - Tried different usb''s, all formatted to FAT16 - Tried resetting the tv I only can browse to the map, Tizen, Userwidget, but tv cant find the files in the map. Also no pop-up when the USB is on FAT16, it does when its on FAT32 Help :(
Luke 42239 Posted December 11, 2020 Posted December 11, 2020 7 hours ago, CogyG said: I have the same problem. - USB is 3,4 gb - Tizen.rar file on the usb - Unpack with the maps on the usb - Tried different usb''s, all formatted to FAT16 - Tried resetting the tv I only can browse to the map, Tizen, Userwidget, but tv cant find the files in the map. Also no pop-up when the USB is on FAT16, it does when its on FAT32 Help Hi, what model do you have?
