Teddy 100 Posted September 19, 2020 Posted September 19, 2020 (edited) I have some same shows in different formats, 4K, 1080p, SD ..... But for example in the show The Boys I'm watching it in 4K but in "Next Up" you can see both formats. Is there any way that "Next Up" only shows the format of the series I'm watching and do not duplicate it? (I Attached a screencopy) Edited September 19, 2020 by Teddy
Happy2Play 9802 Posted September 19, 2020 Posted September 19, 2020 If they are in different libraries, they will show separately or as many different versions that you have as they are not grouped/multi-versioned.
Teddy 100 Posted September 19, 2020 Author Posted September 19, 2020 Yes, they are in different libraries. But then, there is no solution to this behavior?
Luke 42210 Posted September 19, 2020 Posted September 19, 2020 Yes, merging them, or use the next up that is underneath the library rather than the one on the home screen which is for all libraries.
Teddy 100 Posted September 19, 2020 Author Posted September 19, 2020 Thanks Luke for help but Sadly duplicate shows are not in the same library so they cannot be merged as single shows.
Carlo 4561 Posted September 19, 2020 Posted September 19, 2020 Hi, as Luke mentioned use the Next Up in the library itself so you'll only get that version.
Happy2Play 9802 Posted September 19, 2020 Posted September 19, 2020 This will be a drawback of any Row that presents for all libraries in a multi-library environment. You should see almost the same thing via the Continue Watching row also. At least in the web client you would just click the Latest TV header to jump to that Libraries Suggestions next up.
Teddy 100 Posted September 19, 2020 Author Posted September 19, 2020 24 minutes ago, cayars said: Hi, as Luke mentioned use the Next Up in the library itself so you'll only get that version. Sorry, but I don't know how to use the Next Up in the library option. Please tell me how to get it.
Teddy 100 Posted September 19, 2020 Author Posted September 19, 2020 22 minutes ago, Happy2Play said: This will be a drawback of any Row that presents for all libraries in a multi-library environment. You should see almost the same thing via the Continue Watching row also. At least in the web client you would just click the Latest TV header to jump to that Libraries Suggestions next up. Thanks for the suggestion but "Continue Watching row" shows me too big a history.
seanbuff 1353 Posted September 20, 2020 Posted September 20, 2020 1 hour ago, Teddy said: Sorry, but I don't know how to use the Next Up in the library option. Please tell me how to get it. the 'Next Up' section on the 'Suggestions' tab of the library where you want to see only 4K or SD, etc The home screen is giving you a combined view of all of the different versions, you need to view them from their individual libraries if you want a single view of only one quality (version) 2
Teddy 100 Posted September 20, 2020 Author Posted September 20, 2020 Thank you very much everyone for your help, in the end I was able to solve this issue. Regards 1
