RobinM 6 Posted September 18, 2020 Posted September 18, 2020 Hi there, It happens often that chromecast players are stuck in some loop. Dashboard showing they are playing a video, time counter is going back and forth every few seconds. In the meantime the transcoding temp folder is getting filled with temp files (over 20000+ files) and grows huge in size filling my 1tb ssd completely until there are 0 bytes left. What can be done to fix this?
Luke 42208 Posted September 18, 2020 Posted September 18, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a problem. Thanks !
RobinM 6 Posted September 29, 2020 Author Posted September 29, 2020 hi Luke, thank you for your response. I was running Emby behind a reverse proxy. Since a few days I'm not using the reverse proxy setup anymore, moved to a direct connection with SSL. Maybe this was causing the issue, will monitor coming days/weeks to see if the issue will occur or not.
RobinM 6 Posted October 11, 2020 Author Posted October 11, 2020 Hey Luke, Currently seeing almost 60000 (60gb total in size) files in de transcoding-temp folder, so it seems the issue is still there. Provided the biggest transcoding log of october 7th. ffmpeg-transcode-70466b0b-6978-4cff-a306-c4cf2df02d1f_1.txt
Luke 42208 Posted October 11, 2020 Posted October 11, 2020 When you stop playback on the Chromecast, how are you doing that?
RobinM 6 Posted October 12, 2020 Author Posted October 12, 2020 I am not using a chromecast myself. And I have no idea what my users are doing to stop playback. They probably pauze and/or power off the TV. Even after a restarting emby the chromecast player (s) is/are visible as active.
Luke 42208 Posted October 13, 2020 Posted October 13, 2020 Ok we're looking into it. Thanks for reporting.
