muzicman0 85 Posted September 18, 2020 Posted September 18, 2020 Is it possible to change the default audio track? I have an episode whose default is french, and I want the english track to be default.
Carlo 4561 Posted September 18, 2020 Posted September 18, 2020 Hi, In many of the interfaces including web you can select the audio track to use before you start to play it. You can always change the audio track while playing as well. Once you change and start playing the media Emby will remember your selection so if you quit and resume it will use the setting you had previously.
muzicman0 85 Posted September 18, 2020 Author Posted September 18, 2020 Thanks. This was for a non technical friend using an interface that I have never even seen before (Apple TV). I was hoping if I could change it globally, he wouldn't have to worry about it. If it's not possible, then no worries.
Carlo 4561 Posted September 18, 2020 Posted September 18, 2020 I totally understand. Some users have requested this as well for basically the same reasons.
crusher11 1134 Posted September 18, 2020 Posted September 18, 2020 It's possible to do using MKVToolnix to edit the headers.
muzicman0 85 Posted September 18, 2020 Author Posted September 18, 2020 9 hours ago, crusher11 said: It's possible to do using MKVToolnix to edit the headers. sure, I could edit the file, but probably not worth it. He'll figure it out how to change the audio.
