tester12 1 Posted September 17, 2020 Posted September 17, 2020 (edited) Hello, I have a DS418j on which Emby is running. The HDD should actually go into standby after 10 minutes. If I stop the Emby service it works. When Emby is running, the HDD always stay on. It doesn't say anything in Emby's log for hours. I didn't find anything in Emby that could cause it. I switched off real-time monitoring. What can it be? Edited September 17, 2020 by tester12
Luke 42243 Posted September 17, 2020 Posted September 17, 2020 Hi there, please attach the emby server log from when you expected it to go to sleep. Thanks.
tester12 1 Posted September 17, 2020 Author Posted September 17, 2020 As i wrot in this time the log is clear! The HDD should go into standby after 10 minutes. Emby's log is empty for HOURS. Nothing is written to the LOG so the HDD can go into standby. They don't do that as long as Emby is running. So it has to be something from Emby that is not in the LOG
Luke 42243 Posted September 17, 2020 Posted September 17, 2020 Can you please attach the log file anyway? thanks.
