Luke 42241 Posted April 8, 2021 Posted April 8, 2021 9 hours ago, kafisatz said: Thanks! I just ran into this. After browsing through a few other threads about 'no compatible streams' I found this. Solved my issue. Thanks for the feedback.
cp41 42 Posted March 15, 2022 Posted March 15, 2022 On 10/12/2020 at 10:15 AM, vdatanet said: iOS 14 and padOS 14 has added a local network privacy feature, off by default. Sometimes the user is not presented with the request for this permission or ignores it. Regular users do not know what it is and they answer no, in this case the only option is to authorize the Emby application to have access to the local network. If this is not done, then you get the error "Not compatible streams are found" in an infinite loop. As far as I know, at this time there no API available to check that permission status. I suppose that sooner or later Apple will add this API and developers will be able to check the status of this permission and eventually request its activation. Here's an example: https://www.iphonetricks.org/ios-14-local-network-privacy-feature/ https://developer.apple.com/videos/play/wwdc2020/10110/ There are two ways to do that: Settings - Privacy - Local Network: Settings - Emby: Let me know if you need more screenshoots: Oh my goodness! This solved my issue. It was driving me crazy. Thank you so much!
Luke 42241 Posted June 25, 2022 Posted June 25, 2022 HI, please try the latest update to the Emby iOS app and let us know how that compares. Thanks.
Solution cp41 42 Posted June 25, 2022 Solution Posted June 25, 2022 Updated the app just now and played some files. Everything was working as expected without error. 1 1
