Toppeer 0 Posted February 11, 2021 Posted February 11, 2021 Hi. I solved the problem with this solution. Thanks.
a8500830 0 Posted September 11, 2022 Posted September 11, 2022 Yes, this method no longer works. If there is a proper solution, please reply me. grateful! On 2020/12/19 at AM1点51分, appoli said: 同意。 &如前所述,这似乎也不再起作用了...
Luke 42237 Posted September 14, 2022 Posted September 14, 2022 On 9/11/2022 at 12:02 AM, a8500830 said: Yes, this method no longer works. If there is a proper solution, please reply me. grateful! @a8500830 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
softworkz 5133 Posted September 14, 2022 Posted September 14, 2022 On 9/11/2022 at 6:02 AM, a8500830 said: Yes, this method no longer works. If there is a proper solution, please reply me. grateful! Could you please try the following to change the VAAPI driver: install the Diagnostics Plugin from the Catalog Reboot Make the settings as indicated below Reboot Retry with VAAPI
