Luke 42243 Posted October 8, 2020 Posted October 8, 2020 Regarding the 414, please see my response here: Thanks.
Luke 42243 Posted October 10, 2020 Posted October 10, 2020 For those with an older armv7 Synology can you please try this build: https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.0.2/emby-server-synology_4.6.0.2_armv7_legacy.spk Thanks.
carl3D_embysvr 0 Posted November 10, 2020 Posted November 10, 2020 For the ds218j after having troubles to install the update with the armv8 version of the spk file. It finally worked with the file -->> emby-server-synology_4.5.2.0_armv7
Luke 42243 Posted November 10, 2020 Posted November 10, 2020 3 hours ago, carl3D_embysvr said: For the ds218j after having troubles to install the update with the armv8 version of the spk file. It finally worked with the file -->> emby-server-synology_4.5.2.0_armv7 Hi, yes that makes sense. It is an armv7 unit.
carl3D_embysvr 0 Posted November 10, 2020 Posted November 10, 2020 27 minutes ago, Luke said: Hi, yes that makes sense. It is an armv7 unit. Hi Luke thanks for this precision Where can I find this information ? When I've check on this link -->> Architecture-per-Synology-model it says that the ds218j is an armada38x -->> x18 SeriesSo when I've tried to download the newest update I assume the good one was the ARMv8 (x18 Series) -->> https://emby.media/synology-server.html
Luke 42243 Posted November 10, 2020 Posted November 10, 2020 So then I googled armada38x to find that out. That was a harder one to find then others due to the GitHub page not explicitly saying it.
