knathan89 0 Posted September 14, 2020 Posted September 14, 2020 For some reason, I can’t click on the server when using the LG magic remote. Any solutions? When I click on the wheel using the remote, the server just won’t go
rbjtech 5341 Posted September 14, 2020 Posted September 14, 2020 Is the remote/click working ok in other apps ? If yes, then maybe an uninstall/reinstall of emby will clear it ? If not, then probably re-registering your magic remote may help - have a look on-line for how to do that. https://www.lg.com/uk/support/product-help/CT32002770-1399376482956#:~:text= Magic remote re-registration%3A 1 Press and,the remote pointed towards the TV. More
SamES 1084 Posted September 14, 2020 Posted September 14, 2020 The answer is to exit the app (completely) so that the app restarts, then it will work fine. There is currently an issue with selecting a server straight after it's been added. 1
