Wheemer 50 Posted September 14, 2020 Author Posted September 14, 2020 No proxy setup and firewall is disabled. Thanks! 1
arrbee99 1836 Posted September 14, 2020 Posted September 14, 2020 Probably a good idea to turn firewall back on in the meantime though
Wheemer 50 Posted September 14, 2020 Author Posted September 14, 2020 My router's firewall is still active and I do not wish to use this outside my local network.
arrbee99 1836 Posted September 14, 2020 Posted September 14, 2020 (edited) While I remember, my plugin is here - C:\Users\MyName\AppData\Roaming\Emby-Server\programdata\plugins Does that seem familiar ? I think Emby puts plugins in two locations, hopefully, its the above Edited September 14, 2020 by arrbee99
Wheemer 50 Posted September 14, 2020 Author Posted September 14, 2020 That's where the instructions say to put it, however it did not work there for me. I have to place it in C:\Users\MyName\AppData\Roaming\Emby-Server\plugins
arrbee99 1836 Posted September 14, 2020 Posted September 14, 2020 Interesting. I don't have a plugins folder at that location at all. But I guess it doesn't actually work there either. You did restart the server after you added the plugin ?
Wheemer 50 Posted September 14, 2020 Author Posted September 14, 2020 It does show up when placed in the folder I said. Yes I did restart emby server.
arrbee99 1836 Posted September 14, 2020 Posted September 14, 2020 Guess I'll have to give up again. Maybe when more people are around they'll fix it, no problem, but its a bit quite at the moment. Time zones etc.
Wheemer 50 Posted September 14, 2020 Author Posted September 14, 2020 Very strange but it seems like without changing anything further it's suddenly working just fine. Maybe it took a while to update in the background? Thanks Guys! 1
