Luke 42246 Posted November 21, 2020 Posted November 21, 2020 We don't support switching back and forth. When the stable version number catches up, that's when you can switch.
Joly0 2 Posted November 22, 2020 Author Posted November 22, 2020 Ok, this is weird. I setup a new container using the linuxserver/emby:beta version, and it works, with and without the new decoder, no problem. In the old version it doesnt work
Joly0 2 Posted November 22, 2020 Author Posted November 22, 2020 Btw, just a simple off-topic question, what about emby loosing the thumbnails i upload for folders/moviecollections after a restart? I upload some, set them as primary and as soon as i restart the container, those are gone, same for the official container
Joly0 2 Posted November 22, 2020 Author Posted November 22, 2020 Ok, nvm, i forgot to set the licence. Set it and with the old decoder, it still gives black screen, with the new one, it doesnt, works perfectly
Luke 42246 Posted November 22, 2020 Posted November 22, 2020 7 minutes ago, Joly0 said: Btw, just a simple off-topic question, what about emby loosing the thumbnails i upload for folders/moviecollections after a restart? I upload some, set them as primary and as soon as i restart the container, those are gone, same for the official container We'd have to go over a specific example. Thanks.
softworkz 5133 Posted November 22, 2020 Posted November 22, 2020 (edited) 6 minutes ago, Joly0 said: Ok, nvm, i forgot to set the licence. Set it and with the old decoder, it still gives black screen, with the new one, it doesnt, works perfectly So the actual issue is solved with the new decoder, right? Edited November 22, 2020 by softworkz
Joly0 2 Posted November 22, 2020 Author Posted November 22, 2020 16 minutes ago, softworkz said: So the actual issue is solved with the new decoder, right? Seems like it, yes 1
Joly0 2 Posted November 22, 2020 Author Posted November 22, 2020 19 minutes ago, Luke said: We'd have to go over a specific example. Thanks. What do you exactly mean? I have movies in folders in my file-structure, in those folders are movies that belong to each other. In emby those movies get grouped in the folders they are in and as a thumbnail/primary picture they show the primary picture of the first movie thats in the folder. I can change the primary image of the folder, but those changes dont survive a restart
Luke 42246 Posted December 2, 2020 Posted December 2, 2020 On 11/22/2020 at 3:00 PM, Joly0 said: What do you exactly mean? I have movies in folders in my file-structure, in those folders are movies that belong to each other. In emby those movies get grouped in the folders they are in and as a thumbnail/primary picture they show the primary picture of the first movie thats in the folder. I can change the primary image of the folder, but those changes dont survive a restart @Joly0 Please create a new topic that discusses a specific example and provides the information requested in how to report a problem. thanks !
