moshew 0 Posted September 12, 2020 Posted September 12, 2020 When I run the android TV version of EMBY client, on my Mi Box S device - all the TV shows images disappear, as in the attached images. I noticed that when I switched all the device settings to English, things work fine.
Luke 42246 Posted September 12, 2020 Posted September 12, 2020 Hi, what version of the android tv app?
moshew 0 Posted September 12, 2020 Author Posted September 12, 2020 Android TV 1.8.28.g I believe it's the latest version, since I downloaded it yesterday
vdatanet 1619 Posted September 12, 2020 Posted September 12, 2020 (edited) 3 minutes ago, moshew said: Android TV 1.8.28.g I believe it's the latest version, since I downloaded it yesterday That's the latest release. Join the beta channel and test it, rtl language support is improved. Edited September 12, 2020 by vdatanet
moshew 0 Posted September 12, 2020 Author Posted September 12, 2020 Ok, Thanks. I joined. just to clarify, my problem is only for the TV shows media. all other works great.
