speechles 2062 Posted October 10, 2020 Posted October 10, 2020 (edited) Is it looking inside those PNG and collapsing white space to get 6 when normally it should always be 5. That is what it looks like. Also it isn't using placeholders (that grey/blue/themeable color box) behind the channel logo (these will never be full size) like other apps do. So certain colors on the channel logo are most certainly blended into the background color. @ebr is it possible to use placeholders behind the channel logos? You can use the placeholder to trick the TvOS into not shrinking to 6. Then slap the channel logo on top of that like every other app does it. Is this not possible on TvOS? Just curious. I am suspect the Roku is the most versatile UI of these devices. Since you have to build everything practically from scratch on Roku you get to roll you own. I am guess Apple has only pre-rolls available in TvOS and isn't too keen on allowing you to pack your own cigarettes? Edited October 10, 2020 by speechles
teknokracy 0 Posted November 13, 2020 Posted November 13, 2020 I'm also having the Settings/Search problem. Sometimes they are switched, sometimes I get an error trying to access Settings. This seems to happen on my 4K as well as on my non-4K AppleTV
vdatanet 1619 Posted November 14, 2020 Posted November 14, 2020 10 hours ago, teknokracy said: I'm also having the Settings/Search problem. Sometimes they are switched, sometimes I get an error trying to access Settings. This seems to happen on my 4K as well as on my non-4K AppleTV Try 1.5.0, now it's GA. This should be fixed.
