How to Fix Movies with Loud Action Music and Low Dialogue Volume
I was wondering if anyone could create a plugin or if someone knows how to balance out the audio tracks in the movie files.
Some movies have ok or low dialogues but the action scenes and sound effects are super loud so i was hoping to adjust them for a better viewing experience.
What you are looking for is normally achieved via the client hardware. E.g. most home cinema receivers normally offer "Night Mode", or "Dynamic Range Compression", as well as individually controllable levels e.g. for the Centre Speaker Channel (where most dialogue tends to play).
Implementing it at a software level would force Emby to always Transcode, as it would have to manipulate the audio streams rather than just passing them through
Kodi can do it.
Thank ypu both for your input it's appreciated
Guest
