kirkj 9 Posted September 10, 2020 Posted September 10, 2020 Hello, I am using the naming convention as explained in the documentation, and it is working very well, as long as there are no more than 8 versions of the same movie. See the example below: /Movies /Movie Example (1980) /Movie Example (1980)/trailers/Movie Example (1980) - Trailer.mp4 /Movie Example (1980)/Movie Example (1980) - Version 1.mkv /Movie Example (1980)/Movie Example (1980) - Version 2.mkv /Movie Example (1980)/Movie Example (1980) - Version 3.mkv /Movie Example (1980)/Movie Example (1980) - Version 4.mkv /Movie Example (1980)/Movie Example (1980) - Version 5.mkv /Movie Example (1980)/Movie Example (1980) - Version 6.mkv /Movie Example (1980)/Movie Example (1980) - Version 7.mkv /Movie Example (1980)/Movie Example (1980) - Version 8.mkv In this way the versions are grouped and displayed, including the trailer. But if one more file is added, it will be recognized as a new movie and will not be grouped. /Movies /Movie Example (1980) /Movie Example (1980)/trailers/Movie Example (1980) - Trailer.mp4 /Movie Example (1980)/Movie Example (1980) - Version 1.mkv /Movie Example (1980)/Movie Example (1980) - Version 2.mkv /Movie Example (1980)/Movie Example (1980) - Version 3.mkv /Movie Example (1980)/Movie Example (1980) - Version 4.mkv /Movie Example (1980)/Movie Example (1980) - Version 5.mkv /Movie Example (1980)/Movie Example (1980) - Version 6.mkv /Movie Example (1980)/Movie Example (1980) - Version 7.mkv /Movie Example (1980)/Movie Example (1980) - Version 8.mkv /Movie Example (1980)/Movie Example (1980) - Version 9.mkv In this way the version 9 will appear in the library as a new movie. Manual grouping works, but the trailer is no longer recognized. This happens if the 8 versions are added before and the next ones are included later, but if more than 8 versions are included, automatic grouping does not work, and a movie for each file appears in the library. Version of Emby: 4.4.3.0 Server: Ubuntu Thanks for the excellent work and sorry for any difficulty in explaining, English is not my language.
Happy2Play 9813 Posted September 10, 2020 Posted September 10, 2020 (edited) @Luke this is reproducible. The 9th version breaks auto version grouping and breaks the local trail and uses trailer url. Manually grouping continues to use trailer url. The 9th version 9 individual item in Content type Movies/folder view shows folder with 9 items. 4.5.0.25 Windows Edited September 10, 2020 by Happy2Play 1
Luke 42246 Posted September 10, 2020 Posted September 10, 2020 Yes it's a hard-coded limitation to avoid accidental mis-matches. It's not currently configurable although it's possible for the future. 1
kirkj 9 Posted September 11, 2020 Author Posted September 11, 2020 Thank you guys. Would I have the system use my trailer when grouped manually instead of the trailer url?
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 Try putting the trailer in a sub folder of the individual movie folder - once in a trailer folder can be called anything you like eg. ..\movies\movie name\trailers\trailerfile.ext ..\movies\movie name\trailers\another_trailerfile.ext and you can have as many as you want and work in same way etc 1
kirkj 9 Posted September 11, 2020 Author Posted September 11, 2020 I have a trailers folder and it works normally. The problem occurs when I do the manual grouping, and the system displays the Youtube trailer.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 Ah ok - diff problem then - Luke needs to look at that then 1
Luke 42246 Posted September 11, 2020 Posted September 11, 2020 I would try that again with the next release. Thanks. 1
Happy2Play 9813 Posted September 11, 2020 Posted September 11, 2020 Just now, Luke said: I would try that again with the next release. Thanks. Do you mean 4.6+? As my tests were in 4.5.0.25. 1
Luke 42246 Posted September 11, 2020 Posted September 11, 2020 The 8 limit restriction is unchanged. That's something to potentially review in the future. I was suggesting he re-evaluate this after the next release: Quote The problem occurs when I do the manual grouping, and the system displays the Youtube trailer. 1
Happy2Play 9813 Posted September 11, 2020 Posted September 11, 2020 1 hour ago, Luke said: I would try that again with the next release. Thanks. That is were there is confusion in your suggestion. OP in on 4.4.3.0 and the next release is unchanged. 1 1
kirkj 9 Posted September 30, 2020 Author Posted September 30, 2020 Hi. Today I upgraded the system to version 4.5.1.0, and the problem with the trailer when grouping versions manually continues. Thanks.
Luke 42246 Posted October 3, 2020 Posted October 3, 2020 Right I haven't' had a chance to review this yet, sorry. I think there is risk involved with changing it. 1
Happy2Play 9813 Posted March 31, 2022 Posted March 31, 2022 On 9/11/2020 at 1:30 PM, Luke said: The 8 limit restriction is unchanged. That's something to potentially review in the future. Can this be a value users can adjust even if hidden in config file? As this is still coming up. 1
