rb9999 6 Posted September 10, 2020 Posted September 10, 2020 (edited) I have seen other posts with some of these issues but doesn't cover everything I see. Here is my issue, and it just seems to be happening on one series I have and not seen this problem on other shows yet. I am using a 2019 Nvidia Shield Pro. When I play a particular show on the Nvidia and then stop, it always starts back from the beginning. The resume minimum settings are not and issue. Show is 40+ minutes long and I stop halfway through. Now...if I view that same show on my android tablet, the resume works fine. If I view on tablet, and stop, then go to that same video on my shield, I see the "resume from xx:xx minutes" message on my playback screen. However, when I attempt to resume, the video starts over from the beginning. Also, pressing the fast forward key actually takes you right back to the beginning of the show. Again, if I view the video on my tablet, resume and fast forward works. The video description of the file under more details is: H264 Profile: high Level: 31.0 Resolution: 720x304 Aspect: 45:19 Framerate: 25.0 Bitrate: 539 kbps Bit depth: 8 bit Refframes: 1 Edited September 10, 2020 by rb9999 mistyped
ebr 16338 Posted September 10, 2020 Posted September 10, 2020 Both of those symptoms indicate an inability to seek the item. What is the container?
rb9999 6 Posted September 10, 2020 Author Posted September 10, 2020 From MediaInfo: Matroska: 174 MiB, 45 min 2s 1 video stream: AVC 1 audio stream: AAC LC First Video Stream: English 720*304 (2.35:1), at 25.000 FPS, AVC (High@L3.1) (CABAC / 5 Ref Frames) First Audio Stream: English 44.1 kHz, 2 channels, AAC LC
Luke 42246 Posted September 10, 2020 Posted September 10, 2020 Hi, what version of the android app do you have on the tablet?
rb9999 6 Posted September 10, 2020 Author Posted September 10, 2020 3.1.23. Samsung S5e running Android 10.
Luke 42246 Posted September 10, 2020 Posted September 10, 2020 Would you mind trying this version of the tablet app: Thanks.
rb9999 6 Posted September 11, 2020 Author Posted September 11, 2020 OK. I installed it. Now this version on my tablet is having the same issue. I guess that is what you were trying to determine. Now how do I undo and downgrade? Do I need to do a full uninstall/reinstall?
rb9999 6 Posted September 11, 2020 Author Posted September 11, 2020 (edited) The video I am trying to play is an mkv. Edited September 11, 2020 by rb9999
Carlo 4561 Posted September 14, 2020 Posted September 14, 2020 On 9/10/2020 at 9:35 PM, rb9999 said: The video I am trying to play is an mkv. Hi, can you provide a screen shot of the meta data for that file? You can find it on the detail screen in a web browser.at the bottom of the page. Thanks
Luke 42246 Posted September 14, 2020 Posted September 14, 2020 I responded to your pm. A sample video for testing would be great. Thanks.
