Carlo 4561 Posted September 11, 2020 Posted September 11, 2020 2 minutes ago, Administra said: Of course, brother, I will gladly install it and give you access to the server, only that instead of the program you told me about, I can recommend another one, I use it and I think it is better, there is no need for you to install anything, if you think this is the link https://anydesk.com/en/downloads, just download it and run it, I will give you the key to connect, but if you don't think so, no problem, I can install teamview I have that as well but much prefer using Teamviewer as it provides more information for me to use and adapts to different screen resolutions much better. It has both voice and chat facility built in as well that just works better IMHO.
Administra 1 Posted September 11, 2020 Author Posted September 11, 2020 35 minutes ago, cayars said: In a nutshell AWS changes how you do this. The step we have in our Connectivity doc is a LOT different in an AWS environment. Besides RDP ports you have to setup port forwarding in a unique virtual manner. Check out this doc for info: https://aws.amazon.com/blogs/mt/amazon-ec2-instance-port-forwarding-with-aws-systems-manager/ All right brother, I'm going to see that document you sent me and see if I can solve this, anything I always tell you around here, thank you very much
Administra 1 Posted September 12, 2020 Author Posted September 12, 2020 greetings brother, i already made the configuration of amazon, i created a vpc, an elastic network and an EC2 windows server 2019 and the steps indicated in the document you sent me bro, unfortunately it didn't work, it's hard to access, i think the option i'm going to have is to try with another vps provider
Carlo 4561 Posted September 13, 2020 Posted September 13, 2020 It shouldn't be this hard. I used to run an infrastructure in AWS with websites, SQL Servers, FTP sites all with forwarding and firewall ports opened. The trick is to make the changes in both the AWS setup and on the machine itself. 1
moviesfast 0 Posted January 18, 2023 Posted January 18, 2023 On 13/9/2020 at 2:47, cayars said: No debería ser tan difícil. Solía ejecutar una infraestructura en AWS con sitios web, servidores SQL, sitios FTP, todos con puertos de reenvío y firewall abiertos. El truco consiste en realizar los cambios tanto en la configuración de AWS como en la propia máquina. hello brother I have the same problem and if I have the team viewer so you can help me
Luke 42290 Posted January 20, 2023 Posted January 20, 2023 On 1/18/2023 at 4:05 PM, moviesfast said: hello brother I have the same problem and if I have the team viewer so you can help me Hi @moviesfastcan you please describe your issue in more detail? Thanks.
Carlo 4561 Posted January 22, 2023 Posted January 22, 2023 @moviesfast Have you tried following the directions on AWS? https://aws.amazon.com/blogs/mt/amazon-ec2-instance-port-forwarding-with-aws-systems-manager/ Let us know how you make out following those instructions. Carlo
