tsheley 2 Posted September 9, 2020 Posted September 9, 2020 (edited) I am trying out a month of Emby Premier and I can not get smooth playback. I am running the server on a Windows 10 Machine that also has Plex. My movies in Emby constantly pause and stutter on my iPad and AppleTV. If I lower the quality to 1080p 5mb it plays fine. Problem is I shouldn’t have to do that since if I play the same video in Infuse or Plex and it plays just fine. I have checked and Plex is Direct Playing the video. Also Chromecast from Emby works great with no problems. I have attached the stats of the video. This isn’t the only video that stutters and pauses. Any thoughts? Edited September 10, 2020 by tsheley
tsheley 2 Posted September 10, 2020 Author Posted September 10, 2020 Yes. I used Infuse to connect to Emby and it plays fine.
vdatanet 1619 Posted September 10, 2020 Posted September 10, 2020 1 minute ago, tsheley said: Yes. I used Infuse to connect to Emby and it plays fine. What player are you using in tvOS, native or MPV? Try switch to native player. Remember to restart the Apple TV app.
tsheley 2 Posted September 10, 2020 Author Posted September 10, 2020 (edited) I have tried both. The native player is worse. It pauses all the time. The MPV stutters but doesn’t completely pause. Edited September 10, 2020 by tsheley
vdatanet 1619 Posted September 10, 2020 Posted September 10, 2020 Just now, tsheley said: I have tried both. The native player is worse. It pauses all the time. The MPV stutters but doesn’t completely pause. Both direct playing?
tsheley 2 Posted September 10, 2020 Author Posted September 10, 2020 The same movie plays fine in Infuse connected to the Emby Server and plays fine over ChromeCast from the Emby Server. It also plays fine from my Plex Server.
Luke 42242 Posted September 10, 2020 Posted September 10, 2020 Can you please attach the emby server log from when you played? Thanks.
tsheley 2 Posted September 10, 2020 Author Posted September 10, 2020 Sure thing. Here is the log. Have been playing around with the file and if I run it through FFMPEG and move the MOOV Atom to the front the file plays fine. No other change to the file just moving the MOOV atom. embyserver.txt embyserver MOOV Atom Move.txt
Luke 42242 Posted September 10, 2020 Posted September 10, 2020 HI, that's great info, thanks. As a test though, if you run it through ffmpeg without making any changes, what happens with that output?
tsheley 2 Posted September 10, 2020 Author Posted September 10, 2020 (edited) So running it through ffmpeg without moving the MOOV Atom works also. Here is the command I am using.... ffmpeg -i "C:\Avengers - Endgame (2019)\Avengers - Endgame (2019).m4v" -codec copy -map 0:0 -map 0:1 -map 0:2 -map 0:3 "Avengers - Endgame (2019).m4v" For the MOOV atom move I added -movflags +faststart WIth this I am only mapping the Video, Stereo, 5.1 and subtitle track. Strange thing is why does the original file work in Plex, Infuse, and Chromecast. I would really rather not run this command on my 400+ movies. Edited September 10, 2020 by tsheley
tsheley 2 Posted September 10, 2020 Author Posted September 10, 2020 Really want this to work. I am tired of Plex.
tsheley 2 Posted September 10, 2020 Author Posted September 10, 2020 (edited) These are all iTunes purchases that I converted via TunesKit M4V Converter. Edited September 11, 2020 by tsheley
vdatanet 1619 Posted September 12, 2020 Posted September 12, 2020 On 9/10/2020 at 8:24 PM, tsheley said: Really want this to work. I am tired of Plex. Plex doesn't direct play anything, it always repacks the file. In Plex control panel you see Video Direct Play and Audio Direct Play, but in fact, it's direct streaming. And Infuse... well Infuse is the best player available for iOS and tvOS. I'm hoping that one day Emby will have a player similar to Infuse.
unisoft 355 Posted September 14, 2020 Posted September 14, 2020 On 9/10/2020 at 10:11 PM, tsheley said: These are all iToons purchases that I converted via TunesKit M4V Converter. I do similar using lossless MP4 but DO NOT have any issue, I use BOX app to repackage as an MKV as ToonesConverter does not support lossless MKV creation. Apple's NATIVE player plays them just fine (albeit Emby Sever re-packages the MKV back to MP4 most likely?). This is when using tvOS 13.xx on an HTTPS WAN connection and they (iToons) play fine 5.1 or stereo sound. Now using the MPV player on tvOS is another story for music videos. Despite all being encoded similarly, it plays some over HTTPS and not others (consistently not random) when Emby is accessed over HTTPS. The same device, same media using MPV on a LAN (not https) works fine! Luke already knows I reported this. Apple native player works fine with them on HTTP or HTTPS LAN or WAN. Those same x264 MP4 High profile circa 8mbps stereo music videos on iOS play a frame every so often (not watchable) when LAN or HTTPS (Wifi issues negated as not any other wifi points around and not a useless ISP router but Asus RT-AC86U with Merlin firmware).
