PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 6 minutes ago, Happy2Play said: I can't remember but I thought we only say the change via the metadata manager. IIRC i think it does more than that as it would not rebuild the db
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 5 minutes ago, PenkethBoy said: IIRC i think it does more than that as it would not rebuild the db Yep just looked at my stable that it changed folder view of every item in MM and folder icon on every item in folder view. system.xml <CollapseVideoFolders>false</CollapseVideoFolders> library options.xml in my case is before <CollapseSingleItemFolders> was added as I have not changed this library or hit save in this library since creation in MediaBrowser server. But would reflect <CollapseSingleItemFolders>false</CollapseSingleItemFolders> if I hit save. All newly recreate libraries are <CollapseSingleItemFolders>true</CollapseSingleItemFolders> even if system is false and new installations have system to true.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 LOL - if i understood that correctly then a bit of a mess
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 Just now, PenkethBoy said: LOL - if i understood that correctly then a bit of a mess Very as the age of your installation can provide different results compared to a install today.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 just checked my test server with has collapse as true and the movies are in folders directly under the movies root folder and i do not get any folder icons in folder Tab view
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 Putting two movies below an Avengers folder - to add an extra folder layer Has produced in the folder tab a "folder" called avengers - with an icon inside that are the two movies Not sure thats what i expected Hmm mess!
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 6 minutes ago, PenkethBoy said: just checked my test server with has collapse as true and the movies are in folders directly under the movies root folder and i do not get any folder icons in folder Tab view Right they are collapsed instead of showing item folder. slightly different as servers are different but collapse vs not Will show additional layer in folder view also
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 with collapse = true get for avengers which i guess is correct as the collapse works on the movie TAB - which thinking about it is where it should work so with the options i have enabled then its working correctly for me
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 27 minutes ago, PenkethBoy said: with collapse = true get for avengers which i guess is correct as the collapse works on the movie TAB - which thinking about it is where it should work so with the options i have enabled then its working correctly for me Correct and in Folders tab you will have a Avengers folder as you have a nested folder structure. Note system collapse true setting overrides library collapse settings. System has to be false for library options to work.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 yes have Avengers folder on Folder Tab now This is not complex at all - LOL @cayars if there is not one already you need to craft a knowledge base article on this before we forget again what option does what / vs server version and when it was created also downsides of changing an option in xml files etc etc Good luck with that
Carlo 4561 Posted September 11, 2020 Posted September 11, 2020 1 minute ago, PenkethBoy said: @cayars if there is not one already you need to craft a knowledge base article on this before we forget again what option does what / vs server version and when it was created also downsides of changing an option in xml files etc etc Good luck with that Drat, now I have to read the whole thread to make sure I understand the request. LOL
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 happy to give you something to do
Carlo 4561 Posted September 11, 2020 Posted September 11, 2020 I'm not sure I'd even know how to document this as the age of the install is going to come into play. What exactly would you like to see documented?
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 (edited) 6 minutes ago, cayars said: I'm not sure I'd even know how to document this as the age of the install is going to come into play. What exactly would you like to see documented? Well who knows when/if Luke will actually remove it and when it is removed we will have some angry people as it will force a library rebuid on their systems and or make user upset they don't have this view anymore. On 12/16/2019 at 7:42 AM, Luke said: This is actually intended behavior. That flag is not meant to be a personal preference. One day it will go away. https://emby.media/community/index.php?/topic/80488-folder-view-home-videos/ Edited September 11, 2020 by Happy2Play
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 36 minutes ago, cayars said: I'm not sure I'd even know how to document this as the age of the install is going to come into play. What exactly would you like to see documented? Even more reason to have a document on how it is now with the various options that affect what a user sees and how emby works yes its complex as it took happy and me a few minutes to remember and figure out whats going on etc etc
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 I honestly don't believe this has anything to do with OP issue as I can reproduce the issue with these season folder names and using proper season folders it is identified properly.
Carlo 4561 Posted September 11, 2020 Posted September 11, 2020 That's what I was thinking just reading this Happy2Play but didn't test anything so I didn't want to comment.
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 (edited) The issue here is from the changes that happened in the Auto detection system (Jellyfin does not have) that applies to Mixed content being used in TV Show content type to allow users to use a nested/complex folder structure. And this system is not locking said series folder as a series folder and moves to the season folder and make it the series folder. Unfortunately when this happens there is no way to correct it beside only using tv naming support document. Now there is no issue using proper season x folders then editing the Display title in UI/metadata. @Luke can confirm in reference to OP, but my tests provide same results as OP, but still don't know naming scheme used. Edited September 11, 2020 by Happy2Play
gokuz 13 Posted September 12, 2020 Author Posted September 12, 2020 8 hours ago, Happy2Play said: The issue here is from the changes that happened in the Auto detection system (Jellyfin does not have) that applies to Mixed content being used in TV Show content type to allow users to use a nested/complex folder structure. And this system is not locking said series folder as a series folder and moves to the season folder and make it the series folder. Unfortunately when this happens there is no way to correct it beside only using tv naming support document. Now there is no issue using proper season x folders then editing the Display title in UI/metadata. @Luke can confirm in reference to OP, but my tests provide same results as OP, but still don't know naming scheme used. I use, e.g. Slayers - S01E01 - Pilot.mkv I respect the file naming scheme emby uses but I need to have custom folder names.
Carlo 4561 Posted September 12, 2020 Posted September 12, 2020 6 hours ago, gokuz said: I respect the file naming scheme emby uses but I need to have custom folder names. Hi, I've got a decent size library but no anime at all in my collection. I'd like to recreate this and do some testing. Can you tell us: What metadata providers you have enabled for this library. Screen shots would be helpful of the configuration so we get the order correctly. If you've installed any other plugins like the Anime plug that is directly related to metadata Could you open a command prompt and navigate to the TV/Slayers directory as show in the op post TV ├── Slayers ├── 01. Slayers (original) ├── 02. Slayers Next ├── 03. Slayers Try ├── 04. Slayers Revolution ├── 05. Slayers Evolution-R └── Movies Then run "dir /s > dir.txt". That will supply us the folder and file names of all subs. Please upload the dir.txt file and then you can delete that file form the folder. Thanks, Carlo
gokuz 13 Posted September 15, 2020 Author Posted September 15, 2020 On 12/09/2020 at 22:39, cayars said: Could you open a command prompt and navigate to the TV/Slayers directory as show in the op post I gave in and rename all my folders. No point continuing if there's no solution except to cave.
Carlo 4561 Posted September 15, 2020 Posted September 15, 2020 You're now part of the Borg collective and have been assimilated. Kidding aside, is it now working better for you after renaming?
