David Patt 21 Posted September 10, 2020 Posted September 10, 2020 59 minutes ago, gokuz said: Finally got an answer. This worked! Thanks! Glad to help.
gokuz 13 Posted September 11, 2020 Author Posted September 11, 2020 11 hours ago, Luke said: Hi there, we're very happy to help. Bumping a topic only two hours after your previous posting is not necessary. You will always get a response. Thank you for your patience. @David Patt I'm missing alphabetical order when using folders. Also in folder view on my android/iphone apps have this issue, its not showing the 3rd column.
David Patt 21 Posted September 11, 2020 Posted September 11, 2020 1 Alphabetic Order - yes i dont have it either but i use folder structure like this. ANIME ---A ----Accel World ---B---- Banana Fish etc.... ---B---- Babylon etc.... 2 , on Mobile phone even in folder view i have third column
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 use the folder tab at the top and make sure that view is sort by title - then you will have the alpha picker - for Tv Shows
gokuz 13 Posted September 11, 2020 Author Posted September 11, 2020 (edited) 1 hour ago, PenkethBoy said: use the folder tab at the top and make sure that view is sort by title - then you will have the alpha picker - for Tv Shows You solved it! Thanks. Hope someone that has this problem come across this coz as its nowhere in the faq/wiki. Edited September 11, 2020 by gokuz
gokuz 13 Posted September 11, 2020 Author Posted September 11, 2020 8 hours ago, PenkethBoy said: use the folder tab at the top and make sure that view is sort by title - then you will have the alpha picker - for Tv Shows Bad news, one problem after another... My server vs TEST VM. Both are using the same folder stucture, same files, everything SAME. Why is one showing a folder icon? I'm stumped once again. This folder icon interferes with the everything and doesn't show, nfo/artwork/description/posters.
gokuz 13 Posted September 11, 2020 Author Posted September 11, 2020 (edited) TOP =MY SERVER Bottom = Test VM Test VM shows perfectly. Why is this? Edited September 11, 2020 by gokuz
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 stop cutting off the top of the screen shot as it allows us to see what page you are on - show the TABS at the top of the page. Post 1. cant tell why you have folder icons - a) have no idea what page you are on b) why do you have them sorted differently Post 2. Looks like you are comparing apples and bananas - but again no context on where the first screenshot came from and what you think is wrong. other than one shows special folder and one does not. Rather than keep posting random screenshots - give details of what screen you are on what options you have applied etc and what you dont understand - so we have a chance of answering you questions besides the screenshot. If you dont people will be less likely to help you.
gokuz 13 Posted September 11, 2020 Author Posted September 11, 2020 1 hour ago, PenkethBoy said: stop cutting off the top of the screen shot as it allows us to see what page you are on - show the TABS at the top of the page. Post 1. cant tell why you have folder icons - a) have no idea what page you are on b) why do you have them sorted differently Post 2. Looks like you are comparing apples and bananas - but again no context on where the first screenshot came from and what you think is wrong. other than one shows special folder and one does not. Rather than keep posting random screenshots - give details of what screen you are on what options you have applied etc and what you dont understand - so we have a chance of answering you questions besides the screenshot. If you dont people will be less likely to help you. 1st pic = my server 2nd pic = vm I stated it in both posts, hope you read for context next time
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 Without you showing the page headers in your image it is almost impossible to tell what or where you are looking in the UI. It is really hard to say, but one server shows it Identified as a Series and the other does not. Since the system is auto detect content type even though you are specifying one on the library it still has to figure out the layers of folder/series/season and if it does not see proper Season Folder it will get it wrong on occasion. Do you write nfo files and save images with media?
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 Also can you please provides a episode naming scheme.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 59 minutes ago, gokuz said: 1st pic = my server 2nd pic = vm I stated it in both posts, hope you read for context next time i did - your context is missing detail and does not help me or anybody else to figure out what your issue is provide detail or remain in the dark
speechles 2062 Posted September 11, 2020 Posted September 11, 2020 (edited) Yeah. You are asking why is the folder icon not shown all the time when using folder view? Indeed.. I see the same problem and I can give a better example of this issue in Emby server. To reproduce the problem follow these steps: 1) Click Movie library 2) Click the folder tab 3) Notice everything showing on screen has folder icons. 4) Scroll down and notice as you do nothing else that was off the screen has the folder icon.. weird, right? This is consistent across apps the Roku and Web app behave identically. Edited September 11, 2020 by speechles
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 (edited) Interesting - for me with .25 and Chrome 85 i get all the folder icons for each movie - tried two diff libraries - on folder tab - can scroll up and down all stay visible however with TV Shows library i get no folder icons at all on folder tab hmm Edited September 11, 2020 by PenkethBoy
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 (edited) If you are seeing a folder icon on a Series in folder view it means that series is not being identified at the series folder level. Or you have a nested folder structure. Same applies to Movies but primarily nested folder structure. Edited September 11, 2020 by Happy2Play
speechles 2062 Posted September 11, 2020 Posted September 11, 2020 It was annoy me because for new features on the Roku I was assume it was my code not working properly and spent an extra week doing something thinking I had to rethink and refactor code to find the bug. Turned out it was the server when I finally decided to compare to the web app. It is indeed a perplexing problem. But once I saw the Roku makes the same exact move I figure once the server fixes this it fixes it on the apps too. Weird how it affects it differently for different people. Makes tracking this down even more fun, thrilling, and hours long fun...lol.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 ah remember now - emby has the option to flatten folder structure <CollapseVideoFolders>true</CollapseVideoFolders> might be at play here also my movie folders have an extra layer before the movie folders as i make a folder to hold the movie that i then put the movie folder into - so i can group movies together although not for boxset purposes but to limit the number of folders to a degree in the root movie folder and have sequels next to each other - this may be having an effect on what i see. e.g. movies/avengers/age of altron/movie.ext e.g. movies/avengers/endgame/movie.ext 1
speechles 2062 Posted September 11, 2020 Posted September 11, 2020 It might have to do with multiple versions for movies when it shows them as folder icons. @Luke do multiple versions of a movie in the same folder with no sub folders show with a folder icon? It appears they do.
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 Yes I was just thinking those two switches, but is dependent on you install date.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 when did that Collapse config switch appear @Happy2Play do you remember? think its been around for a while as my older servers dont have it enabled which is what i used to try the above but my test server has it enabled
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 4 minutes ago, speechles said: It might have to do with multiple versions for movies when it shows them as folder icons. @Luke do multiple versions of a movie in the same folder with no sub folders show with a folder icon? It appears they do. In my tests no. 1 minute ago, PenkethBoy said: when did that Collapse config switch appear @Happy2Play do you remember? think its been around for a while as my older servers dont have it enabled which is what i used to try the above but my test server has it enabled Beginning of v4 I believe. As we saw it configured then reconfigured as it forced a library rebuild.
PenkethBoy 2068 Posted September 11, 2020 Posted September 11, 2020 ok ta - i prob ensured it stayed disabled (false) at that time when the beta enabled it etc to save my metadata changes etc
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 1 minute ago, PenkethBoy said: ok ta - i prob ensured it stayed disabled (false) at that time when the beta enabled it etc to save my metadata changes etc I can't remember but I thought we only say the change via the metadata manager.
Happy2Play 9814 Posted September 11, 2020 Posted September 11, 2020 12 minutes ago, speechles said: It might have to do with multiple versions for movies when it shows them as folder icons. @Luke do multiple versions of a movie in the same folder with no sub folders show with a folder icon? It appears they do. Actually it does for manually grouped item, but not on automatically grouped items.
speechles 2062 Posted September 11, 2020 Posted September 11, 2020 (edited) 4 minutes ago, Happy2Play said: Actually it does for manually grouped item, but not on automatically grouped items. That is the difference for me and the folder icon inconsistency. Not sure about others though. My concern was that the Roku has to match the web app. Even if the web app is giving bad data the Roku has to mirror that. It cannot try to "fix" things and disobey the server. It must be the messenger only. The messenger doesn't alter the message. The apps are the servers messengers. Having items appear consistently on every Emby platform is the goal. Then as the web app changes and evolves the apps need to do very little to just fall in line and stay consistent. The only issue is when these folders are "virtual" by means of several versions of the same item in folder versus having actual other folders nested within that folder. I thought the folder icon showed nested folders. When a folder was in a folder. Turns out no. It also shows when there are multiple versions of an item in that folder with no other folders nested. This presents the challenge to users to know the difference. Using the same icon for both is confusing. Believe me. Should multiple versions in a folder use a different icon? I mean to alleviate the confusion.. It is hard to get this right. Edited September 11, 2020 by speechles
