lomdar67 0 Posted September 8, 2020 Posted September 8, 2020 (edited) I would love to see an option to configure transcoding on a device base. Maybe in a first version only to enable or disable transcoding on a device base. Later this could be fine tuned. For example I have a Fire TV 4K stick. The stick is "not supporting" Dolby Atmos. So when I choose a Dolby Atmos audio track Emby is transcoding. But when I disable transcoding for the current user, than the Fire TV stick plays the file just finde and delivers a PCM signal to my Denon receiver. Unfortunately disabling transcoding on a user base is not granulate enough. Best regards, Michael Edited September 8, 2020 by lomdar67
Luke 42246 Posted September 8, 2020 Posted September 8, 2020 Hi, did you explore the stats feature in the video player to learn why it was transcoding?
ebr 16338 Posted September 9, 2020 Posted September 9, 2020 Hi. For your specific use-case, there is already an option to do what you want. In the settings in our app on the Fire stick set the Audio option to "Mix down to stereo".
lomdar67 0 Posted September 9, 2020 Author Posted September 9, 2020 Thanks for the responses. @Luke I think it's a subtitle problem. I have to investigate further. Some subtitle related option in the Fire TV client and/or on the server makes Emby transcode the video when I select "Only Forced Subs" in the client... @ebr Why would I select that option? When the Emby player on Fire TV can play the video without transcoding and outputs a PCM signal I still get a very good Surround sound. If I select "Mix down to stereo" I would only get Stereo sound. Or do I miss something here?
Luke 42246 Posted September 9, 2020 Posted September 9, 2020 Can we please look at an example? Thanks.
