deaconf19 2 Posted September 6, 2020 Posted September 6, 2020 (edited) Kodi-Emby-Log.txt System: Mac OS Catalina 10.15.16 3GHz 6-Core i5 8GB RAMKodi Version: LatestPlug-In version: Latest *** Delete Issue *** When I am done with a T.V. series I delete it. 1. Go to my NAS delete the T.V. season within the T.V. folder (I do this though my Windows machine manually) 2. Go to Emby Server update the folder by issuing a new scan(No problems season is removed) 3. Kodi Emby plugin retains the information despite issuing a new scan or rebooting. I thought the plugin was constantly checking in with the emby server for updates. Does this include deletes? If not what is the best way to remove the series from Kodi? ** Playback Issue ** I noticed overtime when I play a T.V. shows it will spin waiting and "timeout" after 30 seconds saying file is not found. I select it again and it immediately plays. Only when I reboot does this stop then build up over time. Notes: My Mac Mini is exclusively for running Kodi and Emby Server. I do not use it for anything else. Attached is this morning logs when it did this with Paw Patrol. Edited September 6, 2020 by deaconf19 spelling
emdubya77 35 Posted September 6, 2020 Posted September 6, 2020 (edited) [deleted] Edited July 6, 2022 by emdubya77
deaconf19 2 Posted September 6, 2020 Author Posted September 6, 2020 I get a delete error related to perms . I need to create an account on the NAS then set that up on Emby I assume so it can delete. TBH I never took the time as I thought it would be a lengthy process. "There was an error deleting the item from Emby Server. Please check that Emby Server has write access to the media folder and try again."
Luke 42234 Posted September 6, 2020 Posted September 6, 2020 10 hours ago, deaconf19 said: I get a delete error related to perms . I need to create an account on the NAS then set that up on Emby I assume so it can delete. TBH I never took the time as I thought it would be a lengthy process. "There was an error deleting the item from Emby Server. Please check that Emby Server has write access to the media folder and try again." Yes if emby server doesn't have delete priveligves then it may be denied access.
deaconf19 2 Posted September 7, 2020 Author Posted September 7, 2020 I am not worried about the delete as much I think I can fix that. My problem is the playback issues I am having.
quickmic 1709 Posted September 7, 2020 Posted September 7, 2020 (edited) Are you using native or addon mode in emby4kodi config? Have you selected autoplay next Episode/TV-show? Edited September 8, 2020 by quickmic
deaconf19 2 Posted September 8, 2020 Author Posted September 8, 2020 (edited) Play next episode automatically = disabled playback mode = Addon (Default) I have enable next video info during playback selected. Edited September 8, 2020 by deaconf19 corrections
quickmic 1709 Posted September 8, 2020 Posted September 8, 2020 Can you please attach a kodi-log-file. And is the issue more or less similar than here: https://emby.media/community/index.php?/topic/87710-emby-for-kodi-playback-problems-in-add-on-mode/&tab=comments#comment-921208 If possible, you can try native mode.
deaconf19 2 Posted September 8, 2020 Author Posted September 8, 2020 I was reading this topic. I just performed a netstat -an |grep 57578 and have over 30 connections from local hosts on the ephemeral high starting from 60985 going to 61022. They are all in a TIME_WAIT status. 1
quickmic 1709 Posted September 8, 2020 Posted September 8, 2020 I'm still reviewing the issue. With your setup, I can rule out performance issues. For the moment, I can only suggest a native path configuration.
quickmic 1709 Posted September 13, 2020 Posted September 13, 2020 (edited) @deaconf19 Please attach a kodi-log-file. Edited September 13, 2020 by quickmic
deaconf19 2 Posted September 13, 2020 Author Posted September 13, 2020 I made changes to the file as per your other thread. I haven't attempted native mode I will test here in a few hours and post a log file. 1
