bulls 1 Posted July 20, 2014 Posted July 20, 2014 when i use the server config page or the iphone app - the tv shows are showing up properly with all the seasons and all the episodes but when i use xbmc/xbmb3c seasons are missing and some seasons only have the same episode listed "08 - the one with the book" for 20 times
xnappo 1611 Posted July 20, 2014 Posted July 20, 2014 That is really odd. Can you try browsing in to your TV collection instead of the 'All TV' node inside Video->AddOns->XBMB3C->[Your TV collection name] ? xnappo
bulls 1 Posted July 20, 2014 Author Posted July 20, 2014 same... seems to be just the text thats off, they play different files depends on the show for friends it goes season 1 lists episodes as "01 - the one with ..." 20 times , same up to season 8 "08 - the one with " but season 9 displayed normal curb your enthusiasm only has season 2,4 listed alias (before going in it says "100 episodes" but when you go inside, its empty - has no episodes again this is only on the computer running xbmc/3c
xnappo 1611 Posted July 20, 2014 Posted July 20, 2014 (edited) Very, very odd. Please turn debugging on to level (1) in the XBMB3C settings and post a log. You actually have all those episodes for 'Friends' or are some virtual? xnappo P.S. If you have port open, easiest would be if I could connect and debug. If you are 'open' to this PM me the info. Edited July 20, 2014 by xnappo
bulls 1 Posted July 21, 2014 Author Posted July 21, 2014 (edited) sorry had to step out... ok my bad...guess i was hallucinating ... the webclient & iphone & xbmc/3c do the same thing showing the same episode name over and over (replacing correct episode names), just that the web/iphone show the empty season folders whereas the xbmc/3c does not ... so this is somekind of MB/scraper issue Edited July 21, 2014 by bulls
bulls 1 Posted July 23, 2014 Author Posted July 23, 2014 Curb Your Enthusiasm\Season A\Curb Your Enthusiasm - 0Ax0B - ep name.ext -- only seasons 2,4 get recognized and only few episodes there Friends\season A\0A0B.ext -- see above Alias\S0B - ep name.ext -- none are recognized
